Hi Fellas,
Got the 3/1 totally striped down, every pipe, nut bolt, stud & bush removed from the block, time to clean it all out, It has about 3 inches for sluge in the case, and about 50 years of crap, But it all came apart ok, I have heaps of new parts for it, It is being painted in 2 pack paint, Nice and bright, Mid Brunswick Green, ( I think thats the right Color, ) So I have been told
The list of new parts
Rings
CR Bearing
Crank Bearings
Cam Shaft Bearings,
Tappets
Valves
Injector ( Had none )
Fuel Pump
Push Rods, ( Had None )
Crank felts
Oil Slingers
Gib Keys
Oil Strainer
Gasket Set
Head Gasket
New Studs, Nuts & Bolts
Plus other bits
I have had the Cylinder redone, But not as a Listard, Only a plain bore, as no one was willing to do it for me,
All i need to find now is the side plate on the cylinder, NOT the one that holds the filter,
Anyone have one
Scotty
