Quinn---
My gears were not marked in any way....not even timing marks on them. The engine is a Prakash FuKing and, as you can see by the photos on George's site, was pretty much as crude as it could be made and still run, but the holes and decks and location points are straight and square so the foundation is good and the details bad. I can fix details but not foundations.
I'm running an experimental gear from Joel now that so-far shows NO wear except tooth polishing and I don't hear the clatter of the gears as much. I'm paying close attention to backlash all the way around the gear. They fail by wearing away most of about nine teeth. A new gear should have NO backlash in that particular spot....mine is consistent all the way around. That means the wear came under power, by force, instead of from a miss-fit. Hopefully the harder gear from better material will solve the problem forever.
Valve guides have come a LONG way since lead-free fuel came along. Bronze or cast iron used to be the standard, but with no (lubricating) lead in gas engines and the drastic increase in head temperatures in modern engines have made ceramic guides and Hastaloy valves a good choice. They're usually sealed at the top and get no oil at all.
http://www.anchorbronze.com/ This site *really* opened my eyes to the possibilities of alloy bushings and their design.
The Listeroid is built so that the oil in the valve guide recesses under the springs serves as a reservoir for valve stem lubrication. The exhaust valve guide has a slight 'bell' near the bottom internally that fills with carbon and acts as an oil seal. (Clean that recess every 500 hours or so). The intake tries to draw oil down the stem on every intake stroke. The figure eight groove in the top of the intake bushing will spread the oil around the valve stem some and prevent 'channelizing' of the oil "flow"....actually very little oil is present there and one reason the sintered oil-lite material may be the best choice.
I was surprised at the wear of the cast iron guides in 2000 hours, but there’s cast iron and then there's *Indian* cast iron. Mine is probably from the same outfit that supplied the pinion gear. (I heard they lost their boat anchor contract because the porosity made them float.
I talked to an old friend yesterday that's re-bushed a BUNCH of valve guides. He suggest making new bushings from oil impregnated bronze and said doing the job on the lathe with the guides out of the head is best in this case. Factory bronze bushings are usually very thin and have to be internally swaged to keep them in place. That’s done during the sizing operation. By making a thicker-walled bushing I can just press them into place then finish ream the bore for a valve stem slurp fit. No oil grooves are needed with sintered/oil impregnated material, just a 'funnel' chamfer at the top of the guide.
"Wonder what the Brits used...?
ME TOO! I'd love to have an original Lister just to look at, inventory and examine, but I've never seen one.
As a pure gun guy with a penchant towards perfection, I've studied and worked on a LOT of English guns....even been to England to see for myself.
The mechanical designers and craftsmen in Briton 'between the wars' were some of the best the world has ever seen. They took a 'worst case scenario' look at everything and then designed 'prevention' into the original parts. The quality of the materials, whether for furniture, guns or engines, was the best the world has ever known, before or since. I saw common *windows* in Scottish farm houses that would cost more to make now than the wall to put them in! Amazing detail and over-engineering. I love it!
Here's one of my favorite web pages to show people that say "You can't expect something to last forever.."
http://www.greenandcarter.com/
