Author Topic: Changfa Radiator - And Alternator  (Read 10231 times)
VeggieDiesel
« on: February 17, 2008, 05:03:25 AM »
Hi Guys
For anyone interested, I posted some pictues of the Changfa integral radiator/fan cooling system on my website.
There's an interesting twist. When I removed tha radiator cover, I found 3 wires extending from the center of the fan bearing hub. Could this be the low wattage battery charging alternator ?
The alternator which typicaly resides behind the flywheel does not seem to be there.
I put a picture of this on the site also, in the hope that someone could help me identify the wires.
web site: www.logicworks.ca
Veggie
PS: Moderator, please delete the previous message with the bad link. Thanks
« Last Edit: February 18, 2008, 09:50:15 PM by Veggie »
    • Doug's Petteroid Stuff
Re: Changfa Radiator - (Repaired link)
« Reply #1 on: February 17, 2008, 05:14:00 PM »
I don't see the wires your talking about but it has been documented that there is a simple charging system in some of these engines built into the cooling fan.
dieseldave
« Reply #2 on: February 17, 2008, 06:24:09 PM »
  Probably a smalll permanent magnet alternator(no brushes). Put a voltmeter on it and see what it reads!
  Looks like a great idea,if thats what it is!
« Reply #3 on: February 17, 2008, 06:54:21 PM »
St heads are a throw back very few new machines of any size are built with slip rings anymore.
Looking for them under fly wheels and in modern AC machines of any kind is sort of like looking for a distributor cap and points in a modern car....
shipo
« Reply #4 on: February 17, 2008, 10:13:12 PM »
That could be your alternator/fan...see okiezeke WEICHAI 1115
http://listerengine.com/smf/index.php?topic=1932.0
Changfa 195/10k
Changfa 170R
BACKROAD
  • BAGDAD.......AZ
« Reply #5 on: February 18, 2008, 12:11:00 AM »
Both of my, built in 1980 195's, came with their little radiator and fan.  Neither of them have the alternator/fan combo.  Both of them have the alternator behind the flywheel.  If anyone want's the original radiator's, you're welcome to mine.  Soon to have real ones. :D
Dung-fong #1 - Mfg. Date 1980/8kw Winco gen...In pieces
Dung-fong #2 - Mfg. Date also 1980/8kw Winco gen...runs
      totally awesome after 10+ years of sitting.
1987 Ford F350, crewcab, dually 4X4.....Cummins Powered...
1956 Willy's all-a-round great four wheeler, VERY CUSTOM....
VeggieDiesel
« Reply #6 on: February 18, 2008, 01:56:31 AM »
Doug,
If you go back to the website, look under the "Cooling" section. It's the picture at the bottom of the page.
My hand is holding the three wires which originate at the center hub of the fan.
www.logicworks.ca
Veggie
« Reply #7 on: February 18, 2008, 03:09:43 AM »
There you have it then yours came with an alternator.
If I recall correctly there is a wiring diagram at Utterpower
SCOTT
« Reply #8 on: February 18, 2008, 03:20:34 AM »
test it with a multimeter
net metering with a 6/1 in Connecticut
12/1
6/1
« Reply #9 on: February 18, 2008, 03:27:30 AM »
That won't tell you much without a print.
VeggieDiesel
Re: Changfa Radiator - And Alternator
« Reply #10 on: February 18, 2008, 10:12:15 PM »
Re: Mysterious alternator wires
Gentlemen,
I ran the engine and took some voltage readings.
In case it's an alternator (and not a DC magnet dynamo), I used the AC setting on my mutimeter.
I am not well educated on electrical generator circuitry so perhaps someone could shed some light on this.
Engine running at 400 rpm...
3 Wires (2 red, 1 black):
Red-1 wire to common Black wire = 19.2 volts
Red-2 wire to common Black wire = 19.2 volts
Engine running at 1800 rpm...
Red-1 wire to common Black wire = 27 volts
Red-2 wire to common Black wire = 27 volts
How do I make use of this power?
I assume a rectifier and voltage regulator are necessary, but I don't have a clue what components to get.
The three wires I metered are shown coiled to the left of the starter motor. They connect to the rad fan alternator.
Below the starter, at the back of the engine, there is a module which may be a rectifier ? It has 2 green wires and one red wire.
The red one goes to the RUN side of the ignition switch, and the green wires are not connected to anything.
Changfa makes great engines, but their manual makes no reference to electrical of any kind.
Thanks to anyone who can offer some guidance on this.
PS: Finally figured out how to embed a picture. Neat!!
Veggie
shipo
« Reply #11 on: February 19, 2008, 02:29:46 AM »
Veggie,
I also spend time trying to understand the wiring in 195. I recommend you get the CD from George B. at Utterpower also see the page of one our member here Martin Nile.
  http://martin.nile.googlepages.com/
Thanks to him i found this page..
http://power-co.net/changcharg.htm
Changfa 195/10k
Changfa 170R
« Reply #12 on: February 20, 2008, 12:57:50 AM »
Veggie the green wires apear be coming from your charging system regulator.....
trigzy
    • High Tech Hicks
« Reply #13 on: February 20, 2008, 01:36:06 AM »
Ok,
     Now heres another question before I make an educated guess, what is the voltage between the two red wires?? Hopefully 0??  Or is it double the red/black voltage?  What are the resistance (ohm) measurements between the reds/back and the red/red?
If my assumption is correct, you will be able to hook one red wire & the back wire to those green wires on the regulator, but I'd need those measurements to be sure.
Steve
« Reply #14 on: February 20, 2008, 03:12:04 AM »
Get the prints from Utterpower, less risk of releasing magic smoke
