You could even use the "electric flywheels" that differer from the SOM ones only in that they don't have the twin belt grooves on them. They are the same weight, which is 125 Kg or 275 lbs each as opposed to the regular flywheels which are 65 Kg or 143 lbs each. If you are driving your generator using a flat belt, it makes no difference whether you have the twin grooves or not, it might even be better without them.
Stan
