rca
i am curious
how would you use a 1200 rpm head on a windgenerator?
with a geartrain to speed up to the 1200 or ?
I have a nice low loss planetary gearbox with an ~11:1 ratio attached to a 15 HP, 1725 RPM 3-phase electric motor. Replacing the motor with a 6 pole alternator (1200 RPM for those who don`t know) I can the put a prop on this thing that will spin the gen head full speed with the prop going 109 RPM. That is about perfect for a 35 foot prop with a TSR (tip speed ratio) in the mid 5`s.
Actually that was the original plan to which I spent a whole summer building parts. Turns out I`m not well enough to climb a tower anymore so...... Go to Plan-B.
Vertical axis wind turbine. All the heavy gear, gen head, gearbox, etc. is at ground level. I`ll need additional gear step-up as the vert turbine will turn slower, but a truck rear differential in 6:1 might do the trick prior to the planetary box and provide the 90 degree right angle from horizontical to vertical shaft I need.
