None of the Lister injectors are threaded into the head, and as most foilks find out, if water gets in the injector hole then it can rust in quite badly, always a good idea to apply the oilcan around the injector body occasionally.
Very early Lister CS engines had a water-cooled injector, with coolant around the bottom of the body and O rings for seals.
I have already posted engine numbers for this information.
Two small pry bars and something to protect the machined top face of the block is usually enough to get them out, but as Stan says, they can be well stuck!
Peter
