Author Topic: GF's Lister CS Start-o-matic  (Read 7781 times)
GuyFawkes
    • stuff
« on: February 12, 2006, 07:38:46 PM »
Put this here cos I'm having problems trying to upload stuff to the coppermine, so put files on my webspace and linking here.
Right, this is a Lister CS Start-o-matic that I just picked up, by way of interest I paid 300 UK pounds, which works out about US$523.00
The chap I bought it from had owned it a few years, and run it about 20 hours a year. Just before he sold it it suffered the proverbial frost damage. He was gutted, but when I inspected it I noticed filler, it had gone before, and the previous owner had fixed it with filler and sold it without saying owt.
Mechanically this baby is sweet as a nut, just needs some TLC. Visually it is as ugly as sin, hideous water tank, dreadful trolley, some real botches on the wooden box and water tank, bad paint job, but ALL the original parts are there, even the fuel tank and wall unit.
These pictures were taken with a crappy fuji a202 digital camera, as was the (no sound) 20 second video clip in 640 x 480.
I used a bit of blu-tack to stop the worst of the leaks to run her up properly, so it is still leaking but held enough to run for 20 minutes for testing purposes, as I intend to document this, and so here we start with the "as she came to me" series.
I must also at this time thank my long suffering mother and her neighbours, temporarily for a week or so I had nowhere else to stash this baby except on her driveway, until I can make room in the shop in a week or so's time.
_________________________________
Embedding all those pix here was a mistake, made this thread unreadable
go here for them in a web gallery thingy
http://www.surfbaud.co.uk/Lister/gallery/index.php?
cheers
This first picture is alternator end, note the weighted pulley on the alternator.
This second picture is self evident.
This picture is a close up of the solenoid and linkage for the decompressor, in RUN position
This is the linkage pulled back (opposite of decompress) showing the only missing part, the pin from the solenoid to the lever
This is the oil pump (and cut off switch)
Injection pump, fuel filter, tappets, tappets rotate about 45 degrees per stroke
Injector pump and rack closing arm from the solenoid
Fuel filter
Plate on main bed
Plate on alternator
Control box with +ve and -ve and manual start button on top of alternator
Plate on top of control box
Alternator flywheel
Alternator flywheel again, approx 14 inches diameter
Flywheel, approx 25 inches dia
Flywheel, approx 4 inches wide
Flywheel rim, approx 3 inches thick
Flywheel disk, 1 inch thick
Genuine wall unit, thsi was intended to mount on the wall next to the start-o-matic. Distribution box really.
Close up of plate
Original fuel tank, note fuel level bob indicator
Inside tank, see the float
Float still works as fluid as anything
Pushrods etc
another side view
Genuine lister CS starting handle (I have the other bit of wood from the handle)
Hideous non original and nasty water tank, fuel tank just visible at top
blu-tack leak fix, but compression valve in IN position
compression valve in OUT position (low comp)
The directory containing these files
http://www.surfbaud.co.uk/Lister/pictures/2006-02-12/
The directory containing a 640 x 480 20 second avi of it starting
http://www.surfbaud.co.uk/Lister/videos/
Have phun, any questions ask away.
« Last Edit: February 12, 2006, 09:16:21 PM by GuyFawkes »
DirtbikePilot
Re: GF's Lister CS Start-o-matic
« Reply #1 on: February 12, 2006, 08:26:29 PM »
Frickin' a dude.... I am so jealous!! :o ;D That's totally sweet despite the cylinder damage.  ;D
GuyFawkes
    • stuff
« Reply #2 on: February 12, 2006, 08:31:14 PM »
I had an advantage being 100 miles from where they were built...
If you want revenge go and buy an Indian Super Chief or a clean pan or knuck for a couple  thousand bucks as a barn find....
we can swap
vbg
rgroves
    • Flint Hills Diesel
« Reply #3 on: February 12, 2006, 11:03:47 PM »
I don't see one ugly thing about it.  I can only imagine how sweet that thing sounds.
A country boy can survive - Hank Williams Jr.
GuyFawkes
    • stuff
« Reply #4 on: February 12, 2006, 11:08:37 PM »
she deserves better, and will get it...
will grab some better quality video and audio files, esp close up audio of bearings / tappets / startup / shutdown etc later this week
« Reply #5 on: February 13, 2006, 01:05:04 AM »
Drooled all over my keyboard looking at your new Start O Matic pictures.  Those flywheels look positively menacing.  And all set up on a mobile platform!
What will you do with the cylinder, Guy?  Do you have a parts machine you can scavenge or can it be welded?
quinnf
« Reply #6 on: February 13, 2006, 02:05:44 AM »
Interesting shots of the trolley.  Axle appears to be bending and side shot appears to show the trolley sagging along the long axis.  That's a LOT of weight for wood to bear unassisted by recycled Fiats/TR6s.   ;)
Thanks for the pics.  The flywheels are to die for.  Nice, Nice castings.  Did I say nice castings?
Quinn
GuyFawkes
    • stuff
« Reply #7 on: February 13, 2006, 09:49:44 AM »
As much as I positively HATE plastic metal, having had to contend with it being used in all the wrong places and wrong ways over the years, instead of doing a proper cast weld repair, I have been toying with the idea of a plastic metal repair, as this is one of those few applications where its use will not make matters worse... there are no mechanical loads to speak of, only a water jacket, and there are no temperatures to worry about, and it is not anything except a static part.
I haven't made my mind up yet.
GuyFawkes
    • stuff
« Reply #8 on: February 13, 2006, 09:53:28 AM »
Quinn
the axles aren't bending, they are just loose with lots of slack, but they are shite
the wooden beams have sagged over time, but jack them in the middle and they retain the bend >;^)
