Author Topic: WVO blended with Diesel...in the same tank  (Read 4896 times)
dkmc
« on: July 29, 2007, 11:56:10 PM »
I've read thru the posts here, but I'm not sure I've seen a specific answer to this question.
Rather than have a separate heated  WVO tank, is it possible to just filter it and blend it with low sulfur on-road diesel to run in a VW diesel?  What ratio is possible with no issues as far as thickening in the lines? I can get 5 to 10 gallons of WVO per month, and would rather just add a bit at a time
to the regular fuel tank......if possible.
thanks
dk
villageidjit
Re: WVO blended with Diesel...in the same tank
« Reply #1 on: July 30, 2007, 03:56:40 PM »
thanks
dk
dk,
Field tests done by U. of Idaho using most major diesel engine brands showed definite coking problems at vegetable oil usage of 20% and above.  Lower veg oil percentages seemed not to cause problems.  I have read many private persons recommending up to 35% veg oil as not problem causing, but I seriously doubt most any claims over 20% (unheated) being safe.
Adequate filtering and de-watering should be considered an important requirement, in my opinion (as in many other's opinions).
Vic
Somewhere in the Ozark Mountains, the Village Idiot is missing!
cold comfort farm
« Reply #2 on: September 04, 2007, 09:15:56 AM »
In answer to your question, I run a Kia Sportage and have blended up to 25% filtered wvo in the same tank as my derv. I have not seen any changes to the performance mpg etc and have done over 15k now using this method (20% blended as a min). I live in the sunny UK.
I settle my wvo for a few weeks (if its summer, longer if its winter) and pour the top portion clear wvo through a pillow case inside a 20micron filter which is inside a 1 micron filter. I do not de water as that’s what the cav filters do in the car, just change them a little more often I do them about every 5k and they only cost a few pounds.
Try it at 10% get confidant then add a little more. If you ask 100 people you will get 100 variations I am afraid but 20 25% is safe.  I have run 40% for 2 tank fulls when we had warm weather but would not do it any other time.  Bosch injector pumps tend to like wvo better than Lucas or other ones.
I hope this helps.
Stephen
