Author Topic: The Good, the Rad and the Narly..  (Read 5186 times)
Tugger
« on: July 09, 2007, 10:19:05 PM »
Found a Petter AV1  5.5hp  1800rpm engine generator in a friends garage...
A few cases of cheap canadian beer where traded an i was off with a new toy..
The Good
http://i8.photobucket.com/albums/a5/tuginator/thegood.jpg
Once it was home, my engine guru and i both agreed that the handcrank was not for the AV1, and figured if the engine ever did start it would beat one or both of us to death...
But with new fuel added and a bit of team work i could spin the engine up to speed then remove the handcrank then the guru would drop the compression relief...
3rd try  it started...woohoooo
The rad
http://i8.photobucket.com/albums/a5/tuginator/therad.jpg
The rubber rad mounts are all destroyed allowing the rad to rub on the fan...(Scraping noise heard)
Even with huge dents the thing holds fluids...
The Narly
http://i8.photobucket.com/albums/a5/tuginator/andthenarly.jpg
This big piece of metal is a motor/generator...
When 24 volts is applied it spins the motor fast enough to start the AV1 (this is cool)
The generator part has me a little stumped at the moment...
Would anyone have any info on a :
Hopkinson Motors and Electric Co.Ltd.
NO:06617-21
3KW
60Cycle
1 Phase
1800rpm
CON Rating
110 volts
27.3 amps
