"As for Flaming or putting down other people. It's just not there."
Well I was a memeber at one time and although the post was deleted George did call me an "some idiot". Rumour has it since I was shown the door I've been called some other less flattering things.
We can learn something from that....
Now let me start off by saying yes Bob I read that and I still respect you. The post here he is refering to was some realy bad off the mark advice I gave to a memeber here. I realy screwed up typing faster than reading and not being on the same page as everyone else. And Sayer think of me what you will I have nothing to prove ( I hold more than one ticket in the electrical buisness and I think it fair to say I know a little about it ) and when I'm wrong I admit it. I don't have all the answeres but here in the "Out House" as we are called a man can be wrong and admit it and all posts are here for good history is not rewritten or deleted. And I have been misquoted myself.
And some histories can never be deleted guys
Let the games begin, for this evening listen I have chosen Holst's Mars bringer of War from The planets.
Moderator Join Date: Aug 2006
i saw that post late last night, i woke and got up because i could not sleep
i should have known why i couldn't sleep!
some peoples children,, i swear
yes i believe he has an st head, and it was a piece of crap too, remember?
he broke the end housing trying to tear it down, and Pat had to send him another.. of course he had to desparage him before he gave Pat a chance to send him another housing.
Doug, i know you either will read this or have it forwarded to you by someone, so for godsakes man,,, give it up!
sawyer335
Associate Join Date: Jul 2006
crocks and crocks of sh** from the out house
Yup, here is what a REALLY inexperienced "expert" "senior" poster said there late last night: "Personaly I think buying the Utterpower CD is a waste of time ( and the kit for that matter ).....
136 v no load is a bit low but not by much, personaly I would expect inthe 145 range NL....
Check to see your head has the proper connections.
Test your rectifier bridge.
I'll provide you with part number for a bridge rectifier I use industrial switch gear that has proven itself reliable if you like ( need double check with my stock code for the number ).
All syncronous machines have a high output impeadence, the whole point behind the harmonic winding ( if you look closely you will see there are infact two sets of coils ) is to provide a base excitation and load compensation. Now if something is wrong with your rectifire or connections that might explain a lot"
<OH, just one more please!!! >
"The only fly wheel failure so far has been a Metro.
Another one cracked and shattered a crank.
We haven't seen a KOEL engine yet and Mamad, the Iranian fellow says they are the only ones that aren't junk."
He not only mis-states, but also mis-quotes, etc, etc, etc. And he states that the only flywheel failure so far has been a Metro. I seem to remember that particular "failure" was caused by running with a 'wheel loose!! AND, I would love to know how a flwheel cracked and shattered a crank.
To the best of my knowledge, he owns neither a Listeroid, nor an ST head! (Sorry, he DOES own an ST head he got from "Pat".
