Everything should be bonded anyhow, the shaft, strut, ruder, and especially through hull fittings etc. You should have zinks on the shaft and rudder anyhow and better yet some more fastened anyplace you can put them. Connect a ground strip, preferably copper to everything including the engine. If you have a steel hull you should weld some wherever you can on the hull. usualy every 8 to 10 feet is good, If you have a sailboat don't forget the chainplates, mast etc. Anyplace you can get an addiyional zink below the water line is good. NOTE, when you are at the bock, that is when most electrolysis occure4s because nearby boats with electrical problems as well as dissimilar metals cause excessive electrolysys. You can take A piece of battery cable and put a zink on the end of tio and a battery clam,p o0n the other end. While at the dock clamp the battery clip on to anything else that is bonded to the rest of the boat.
Look for a pipe plug in the water lines in the block. If you can't find one, you can put a piece of pipe in the water line with a T in it. Reduce the third side of the T down to the thread of the zink and install it in the cooling water line. Run a ground from the pipe to the engine. NOTE, be carefull about adding a heavy unsuported pipe to the engine block. Viberation can cause it to break and sink your boat.
