I gather oil with a 12 volt Fil Rite Pump. Its a bit slow, but in the field it is a necesary evail I guess.
1. At home, I wanted to change to a 110 volt pump system to suck and fill my tank. Can I use a water "jet pump" from Lowes and just know it may not last a super long time??
2. Has anyone desinged a valve system to the pump can both suck oil from my gatering tank into my holding tank, then reverse it back into my truck?
3. I have two 500 gallon containers stacked, can I fill the top one, then use a filter inline to fill the bottom one? Will a gravity filter work in this case. Time is not an option, it could drip for all I care...what filter can I put in line?
4. Does anyone know where to get a metal holding tank for behind a resturant?
Thanks
Email: thanson2@houston.rr.com
