Hi
In answer to the original poat. Do you already have a forced air furnace?
If so it would be easy to do. We use a lot of electric heat strips here in Florida. The strips could be put in the sheetmetal plenum (supply or hot air discharge) They are 220v single phase units with exposed terminals. So they shpould have a box covering them, for safety (inqusitive fingers).
one strip is aprox 5kw. stacked up to the capacity you want. These are seond stage heat for heat pumps and primary for straight cool units.
The house thermostat will have to be changed to give you two stage heat. the first stage electric heat will carry the house untill the temps drop enough to bring on the second stage.(oil or gas). This is the easiest, cheapest way to use your lister. also it is automatic, as long as the Lister is pulling the gen load.
If you are intersted I can ship you some salvage units for the shiping$.
PM me or we can discuss it here.
I service these daily here in Fla. I'm planning to use several to load my setup for testing.
What size lister are you useing?
Dennis
