RCAVICTIM:
Talking to both the folks at work, and the FT dealer, I figured out that the $300. was a nominal number that was built into the purchase price of a replacement battery
based on what the value was at the dump. The value / price there is set by the operator of the dump according to a formula set up by the county, which owns the place.
I will get more into this as I go along.
The cell connectors were definitely re-used on the new battery.
I got my PULSETECH unit, it says on the lable. They are supposed to have a web site, but I haven't gone there yet.
I reconnected the cells into 12V blocks to re-cover / re-commision them, then will connect them into 24V packs to run the inverter at my Moms place.
I will build a couple of small carts to be able to swap them out easily during extended power outages. Use 1 there and bring the other home and charge it overnight, then swap again when needed.
There must be a high frequency sound comming from the pulser. Tripod, the three-legged Dawg, and Tipsy the also three-legged Kat are both sitting there staring at it in the classical pose, looking straight ahead with their heads cocked slightly to one side.
So cute it makes me want to cry!!
I'll keepyou posted.
Lots of good will, Wayne.
