Author Topic: Big End Bushing  (Read 3237 times)
Stan
Big End Bushing
« on: April 04, 2007, 11:36:27 PM »
I thought you might be interested in the test fit I did today on the big end bushing in Penelope.  She's a genuine Lister 6-1 and I bought an Indian set of bushings from Troy.  I plasti gauged it today, torqued to 68 ftlbs with no shims.  The results were the same each of the 3 test fittings using green Hastings Plastigage, approx 0.0018 " .  Since the min is 0.0015 and the max is 0.003 I guess they fit pretty well.
Just thought you might be interested.
Stan
lendusaquid
Re: Big End Bushing
« Reply #1 on: May 13, 2007, 10:59:00 AM »
Hello Stan
I am doing the same with my old Lister but i need lots of shims.The Indian lower shell extends the best part of a mm on both sides of the cap.Do you know where i can get some good info on installing shells ?
Graham
Stan
Re: Big End Bushing
« Reply #2 on: May 15, 2007, 05:52:53 AM »
Hi Graham...I don't quite know what you mean by extending beyond the cap.  I guess a picture would help
Stab
