We own a 1935 5-1 which has a worn inlet valve guide.
Recently, our local diesel repair man died, and I was invited to rummage through his workshop and make an offer on any parts I may have wanted.
Wow!! shelves and shelves full of original brand new Lister and Petter parts! Unfortunately not very mush in the 3-1/5-1/6-1 range, although I did find a piston, a couple of sets of rings, some gaskets and a con rod.
Had a good look around the rest of the workshop and lo and behold, tucked away behind a pile of assorted odds and sods was a 6-1 (?) head complete with CO valve, with what appeared to be a new set of valves and springs, and most importantly, no play in the valve guides.
I've taken the original head off Mr Lister and compared it with the new one. I believe the 'new' head might be quite a bit newer than my original one because the paint on it is still in fairly good order, with RA Lister in yellow still visible on the side. I noticed however, that the original head has what appears to be a copper bush in the hole where the injector nozzle goes, whereas the new head doesn't and the hole appears to be about the size of the one in the original were the copper bush to be removed. Also, the injector studs are somewhat longer in the new head.
Apart from that, the two heads appear to be identical.... can anybody telll me if the copper bush is essential? Was it simply left out of later heads?
Any feedback most appreciated.......
