Author Topic: 400Hz  (Read 5050 times)
johnny williams
400Hz
« on: January 19, 2006, 09:39:49 PM »
Does anyone know of an inexpensive device that will convert 400Hz to 60 Hz?
lgsracer
Re: 400Hz
« Reply #1 on: January 19, 2006, 11:08:50 PM »
analog tech motor-generator.
digital tech frequency converter.
both have been used on US submarines. The frequency converter is current issue.
n2toh
Re: 400Hz
« Reply #2 on: January 20, 2006, 01:49:14 PM »
What are you trying to power?
About 60 years is all it takes to make science fiction a reality.
johnny williams
Re: 400Hz
« Reply #3 on: January 20, 2006, 06:13:22 PM »
House,shop whatever
n2toh
Re: 400Hz
« Reply #4 on: January 20, 2006, 06:51:41 PM »
non reactive loads will run on 400Hz no prob, not sure about powering switching power supplies.
I know an old trick to run 400Hz radio gear on 60Hz was to wire a second transformer in with the respective input and output windings wired in series. It usuable ran warm but didn't burn out.
You may want to try running a cheap transformer wall brick on 400Hz to see what happens.
« Last Edit: January 20, 2006, 06:56:06 PM by n2toh »
