Hi there,
I realy must try google to find all the information about electro generators. You will see there are two types field and permanet magnet for the rotor lower power until 1000W can be permanet magnet type whitout brushes and no ware and no voltage regulation.
try a old stepping motor if you want you can use it as generator. the field type yes is using bushes to power the field lowering power to the field wil lower the output voltage. do not stop this type of generator and still having a heavy load you will remove any remaing magnetic from the field coil and your generator will stop working ( a little playing whit a 12 v battery on the field for one second will help to bring your gen to life again).
the system works basicly like this by starting ( whitout load) the remaing mag. field in the field from the rotor start building up a voltage by the ingreasing speed. this start provding voltage to the field coil a strong magnetic field is build up and this is in the rotar and provides a changing magnetic field in the stator coil. as soon as that we have the correct voltage we or stop the voltage to the rotor coil or reduge the voltage. and the is the problem , stoping is a very nasty way to control the voltage (stoping the current we first greats a high voltage piek and then drops the volatge to fast), just lowering the voltage is abetterway but expensive in parts.
i hope this helps, and your reference to the wind generator home build generators using the magnets from microovens and harddisks is only for low power high speed generators.
the magnetic flux is not strong to provide high power.
Greetings from Greece
