Just passing on info here, not complaning, the engine is a good one.
On a new Changfa 1115 Engine / Genset head was cracked under the exhaust valve spring, sort of hard to find. Anyway I recieved a new head. I installed it and after running for about 4-5 hrs the stud that holds the air cleaner in place broke loose from it's weld (inside the piece between the manifold and the air cleaner), rattled free from the top and traveled down through the intake manifold, under the intake valve, across the inside of the cylinder to the exhaust valve. It damaged both valves, bent a push rod and scared the piston a little. What Luck
Yuck!! Anyway, I was able to put the valves from the cracked head into the new one and get her back up and running.
These are certainly tuff engines and are easy to work on.
Ken Gardner
