Author Topic: More Producer gas Petteroids  (Read 2299 times)
« on: January 15, 2007, 03:35:21 PM »
I have several bad images I want to share with the group of two Petteroids running as producer gas engines.
To date never seen this done with a Lister, but I suspect a GM90 would work as well as a Petter....
http://www.putfile.com/dougwp/images
The green clips are of an Ankura gassifier with a Cheap TBR Petteroi piston pump nothin interetsting
The Blue engine is much more interetsting its an air cooled gear oiler, possibly a bushed unit like Gus. And look at the direct coupling of the engine to an ST head so we know this combination is running at 1500 rpm.
