Boy, do I learn slowly,
It's 3am and I just realized I did a newbie. When I took the idler gear out I checked the section on how to mark the idler and cam gears so I could put em back in right. I already had the heads and cylinders off, so I turned the crank till the journal was straight up (on the gear side), then marked the idler and cam gears as shown. Now I'm thinking this might not be a good measure of TDC. When I put it all back together, how can I check that I"m not a tooth (or 2) off on the crank?
Zeke
