If a new diesel engine is ran at low speeds and little or no load, the cylinder will begin to glaze and wet stack. When this happens, you have to pull the heads and cylinders. Then re-hone the cylinders and emery cloth the rings (or replace them), then reassemble.
The piston rings seal proportionally to cylinder pressure, the higher the cylinder pressure the greater the expanding force of rings to the cylinder walls. Therefore, under high cylinder pressure the rings offer the highest sealing capability.
John is correct, run a heavy load. Heavy surges would not be good for a new engine. In your case I would run 4 - 1,500 watt heaters, 2 per hot 120 lead. This would place a constant load of 4,500 - 6,000 watts to the generator and proper loading to seat the rings.
I would run it 24 hours a day until the rings seat, this will accelerate the break in. By operating at full temperature under load and not starting and stopping the engine, to allow it to cool. This promotes cylinder glazing.
Good luck and I hope this helps.
Diesel Guy
