Author Topic: 60 hz cycle  (Read 13137 times)
GeckoPower
  • If it's not broken fix it anyway!
60 hz cycle
« on: January 03, 2007, 05:43:47 AM »
I have a 5 kw ST head 6/1 GTC  engine.  I am running 240 volts from alternator.  I have one P3 kill a watt meter in series on each leg of output.  My voltage is at the high end 125v- 126v no load and about 56.7, 58.1, at times going down to 55.? at times of high load. Normal load, right now on one leg is 115.3 volts, 0.66 amps, 56.7hz.  Is there a problem with the head or is this just normal for the unit?  Slow clocks aren't much fun.  Also, has anybody wired in an ONEAC power conditioner to solve those flickery lights?
Thanks,
Off grid since Sept 1 2005,  1 online GTC 6/1, 5k head;  1 wore out 5 hp 2.6kw Honda (but still starts 1 st pull and will put in a 12 hour day;  1 wore out Honda 1kw when I got it, then I wore it out some more; 2004 Duramax Chev 1 ton; 35 hp New Holland Compact Tractor
rcavictim
Re: 60 hz cycle
« Reply #1 on: January 03, 2007, 12:51:39 PM »
Thanks,
Welcome to the forums!  Frequency has nothing to do with faults or shortcomings in the ST head and everything to do with the shaft speed it is turning at.  This boils down to the engine speed regulation.  Apparently at high loads you either have some severe belt slip or the engine is not maintaining a constant RPM.  This is normal to some degree.  The governors on these engines are not high precision.
Forget trying to run line synchronous clocks when battery powered clocks are so cheap nowadays and AA battery will run one for more than a year.  I recently bought a clock that has a radio receiver and computer in it.  It monitors the 60 KHz WWVB asignal from the atomic clock center of the National Buro (I can`t spell that word if my life depended on it) of Standards in Boulder, CO. and keeps itself set accurate to the top of the second.  Amazing!
-Changfa 1115
-Want Lister 6/1
Jim Mc
Re: 60 hz cycle
« Reply #2 on: January 03, 2007, 01:36:12 PM »
The frequency  of the ST head output (or ANY alternator, for that matter) is soley a function of the speed it's driven.  For 60 Hz, you need 1800 rpm.  If the engine governor allows the engine to slow down a bit under a large load, or if your belt slips, you will see frequency decrease.  The numbers you show (as high as 58.1 and as low as 55) are pretty good for a Listeroid, but do indicate you could bump the engine speed up a bit.  But the variation (3.1Hz) is something you'll have to live with.
In other words, everything you describe seems normal, but you could get closer to 60 Hz if you increase your engine speed a little bit.
tim
Re: 60 hz cycle
« Reply #3 on: January 03, 2007, 02:45:35 PM »
GeckoPower
Go to utterpower George has the govener mod that you can build yourself . It does work. I've changed both of mine.
Tim
ronmar
Re: 60 hz cycle
« Reply #4 on: January 03, 2007, 03:14:39 PM »
These non regulated/harmonically excited gensets also wind up linking voltage output to RPM to a certain extent.  If everything is right, the frequency will be 60-61HZ with a voltage a little on the high side of normal(125/250) with no load.  If your voltage is excessive when you get the engine RPM up to the point of providing 61HZ,  You may have to alter the freq/volt/RPM relationship by putting a resistor in line in the field circuit to limit the field current to lower the voltage being produced on the stator windings to an acceptable level.  If setup on the high side with no load(61HZ/125VAC), the genset should droop into the correct area (60HZ/120VAC) as load is applied and should still be at an acceptable level at full load(58HZ/115VAC).
Georges site has some excellent info on modifying the field current to tune the genset for proper output.
Ron
PS 6/1 - ST-5.
GeckoPower
Re: 60 hz cycle
« Reply #5 on: January 04, 2007, 04:42:57 AM »
Thanks to all who have replied,
I just turned up my electrical world by 2 Hz.  My voltages are about 125 - 133v.  I hope this doesn't damage stuff.  I have faith and warranty so all is well.  I have read the Utter Power web site and have done the governer mod.  The resistor in the field winding may be a little over my head, but I got this far, so it shouldn't be that bad.  Anybody know a source for the resistor?  Also, I have twin 8 rib serpentine drive belts so there shouldn't be much slip.
rcavictim
Re: 60 hz cycle
« Reply #6 on: January 04, 2007, 07:20:34 AM »
Geck,
Do you have the resistance rating in ohms of the required resistor and also the wattage rating?
-Changfa 1115
-Want Lister 6/1
rmchambers
Re: 60 hz cycle
« Reply #7 on: January 04, 2007, 12:50:39 PM »
Wasn't putting a variable resistor a better suggestion as it allows the operator to tweak the power going to the coil in order to fine tune the output power without the need for a major surgery?  What would be the range?  somewhere encompassing the discrete value of the resistor George recommended?
rcavictim
Re: 60 hz cycle
« Reply #8 on: January 04, 2007, 04:02:37 PM »
rm,
You are absolutely correct and you can get ceramic resistors with the resistance wire wound on them with a tap that can be moved and tightened down at the desired setting with a screw.  First you have to know the discrete value of resistance George suggested, which was my question still  awaiting an answer.
-Changfa 1115
-Want Lister 6/1
adhall
Re: 60 hz cycle
« Reply #9 on: January 04, 2007, 05:31:13 PM »
50 Ohms / 50 Watt is what is shown on the website.
Here's the link:
http://www.utterpower.com/vreg.htm
If you are the sort of person (like me) who enjoys adjusting things all the time, you may want to consider something like this:
[url]http://rocky.digikey.com/WebLib/Ohmite/Web%20photos/RJS%20SERIES.jpg[url]
Best regards,
Andy Hall
« Last Edit: January 04, 2007, 07:10:29 PM by adhall »
rcavictim
Re: 60 hz cycle
« Reply #10 on: January 04, 2007, 06:02:16 PM »
5 watts is easy and you can actually get wire wound  ceramic potentiometers from Ohmite that will handle that and give the ease of a control knob like a volume control to set things.
-Changfa 1115
-Want Lister 6/1
adhall
Re: 60 hz cycle
« Reply #11 on: January 04, 2007, 07:15:42 PM »
OOPS--I made a typo--That's 50 Watts (please note I corrected my original post).
This is a fairly large device and a relatively low resistance value, too.
Best regards,
Andy Hall
rcavictim
Re: 60 hz cycle
« Reply #12 on: January 04, 2007, 07:34:23 PM »
Best regards,
Andy Hall
No problemo.  The ohmite series of pots is available in such a wattage and R rating. Hmmmm is that resistor R-rated?  ;D That would likely be one of dem 4 inch diameter jobs.  Prolly only cost about $250.00 wholesale.  A bargoon!  I used one of those as a controller for the electric trailer brakes in my Chevy van one summer.
The unreasonably high cost of hardware and components now resembles a drug induced nightmare.  I think the `executives` that set the prices on this stuff must be on halucinogenic drugs and need the high revenues to support their drug habits.  I have no other explanation that makes any sense.   :'(  The only way a DIY`er like me can afford to make stuff is to find the major parts at the dump or scrapyards and surplus sales.
« Last Edit: January 04, 2007, 07:39:24 PM by rcavictim »
-Changfa 1115
-Want Lister 6/1
rmchambers
Re: 60 hz cycle
« Reply #13 on: January 04, 2007, 08:05:28 PM »
adhall
Re: 60 hz cycle
« Reply #14 on: January 04, 2007, 08:15:08 PM »
Or you can pick one up from Fair Radio Sales for US$2.25. Take the savings and buy yourself a nice, big, old fashioned, Bakolite (sp?) knob to suit!!
See link below:
http://www.fairradio.com/catalog.php?mode=view&categoryid=4233
Best regards,
Andy "The Cheap Swede" Hall
