July ’06 iteration, includes the Windsor and the “mini-listers” of the Topland group.
I have gone to the various manufacturer’s websites and assembled the following from their information. Some provide a lot of useful information, one provided a table of numbers with no labels as to what the numbers meant! None of them talk about sand in the sump. Some mention balance. It seems that the bore and stroke imply the degree of standardization between engines, which I thought might be useful. A few use the same piston and con rod in all their engines, others only vary the piston. A few change both. The dimensions of the foundation bolts, which may not be particularly useful in itself, would tend to indicate whether a different casting is used for the base.
“Standard”: 114.3 piston, 139.7 con rod. Con rods go from 130 to 177.8. Other common pistons are 120, 127 and 130. Materials are mostly iron, few aluminum. 330x330 mm foundation bolt for 1 cyl., 381x559 for 2 cyl., some variation. 5/1, 6/1 and 8/1 are often the same engine, only with an increase in rpm from 600, 650 to 850 (and likely with smaller diameter, heavier flywheels).
Other observations: 14/1 and 16/1 are most often made from odd sized or “non-standard” pistons or con rods. Oil capacities are not given for many of the engines, but the Kirloskar capacities are about half that of other manufacturer’s for the 6/1 & 8/1. The Hindustan Trading Co. “Mini-Listers” appear to be a considerably different design than that offered by others. The piston sizes are “standard” but the con rod and foundation bolt patterns are different than any other engines. Direct Injection implies a different head design than “standard”, and may have an aluminum piston.
Ammerajkot
http://www.ameerrajkot.comH.P./Cyl. 5/1 6/1 8/1 10/1 12/1 14/1 14/1
Bore in MM 114.3 114.3 120 127 139.7 130
Stroke in MM 139.7 139.7 139.7 139.7 152.4 147
Speed RPM 600 650 850 1000 650 1000
Compression Ratio 1:18
Lub. Oil Capacity (Lit.) 4.5 5.0
Foundation Bolt Spacing in MM 330 x 330
Fuel Tank Capacity (Lit.) 14.0
The 14/1’s are two versions, one with larger piston & longer stroke but lower speed, the other with smaller piston, shorter stroke but higher speed. The 14/1’s use unusual piston and con rod’s. I wonder if there was a typo in their spec. sheet – why would they use a piston exactly the same size as a standard con rod?
Ampro Exports
http://www.amproexports.com/lister-diesel-engines.htmlH.P./ Cyl 6/1 8/1 10/1 12/1 14/1 16/1 12/2 16/2 20/2
RPM 650 850 1000 1000 850 850 650 850 1000
Bore 114.3 114.3 120 127 152.4 152.4 114.3 114.3 120
Stroke 139.7 139.7 139.7 139.7 177.8 177.8 139.7 139.7 139.7
Bolt spacing 330 x 330 14, 16=356 x 356 2 cyl. = 381 x 559
Fuel Cap.(Lit.) 8 8 10 10 12 12 12 12
Lub. Oil Cap. 5 5 5 5 7.5 7.5 7.5 7.5 13
These all use the same con rod, except the 14/1 and 16/1. Piston size and rpm varies. Ampro uses the unusual 152.4x177.8 piston & con rod in their 14/1 and 16/1 – these engines also have an unusual size of foundation bolt pattern. They offer what appear to be direct injection engines (“New Variety”), similar to (or the same?) as Satyajeet GM-90 in 6, 8, 10, & 12/1 models. Check out their toilets (water closets)!
Aswamegh
http://www.indiamart.com/ashwamegh/#diesel-engineH.P./Cyl 6/1 8/1 10/1 12/1 12/2 14/1 15/1 16/2 20/2 20/2
RPM 650 850 1050 1000 650 1000 1000 850 1050 1000
Bore 114.3 114.3 114.3 114.3 114.3 130 130 114.3 114.3 120
Stroke 139.7 139.7 139.7 146.05 139.7 139.7 145 160 139.7 139.7
Compression ratio: 18:1, except 14/1 and 15/1 which are 16.5:1. They are Direct Injection engines.
All 2 cylinders have bush main bearings and oil pump, can be ordered with taper roller bearing. 6/1 and 8/1 are splash only, but can be ordered with oil pump. Same piston except 14/1, 16/1 and 20/2. Con rod the same except 12/1, 15/1 & 16/2.
Atul Group
http://www.atulgroup.comHP 6/1 8/1 10/1 12/1
Bore 114 120 120 127
Stroke 139.6 139.6 139.6 139.6
All use the same con rod, but it is 0.1mm shorter than the standard. Is it really different or not?
Crossword Agro Industries
http://www.crosswordagro.com/english/ssde.htmHP/Cyl. 6/1 8/1 10/1 12/1 12/2 16/1 12/2 16/2
See Nissan engines below.
Field Marshall
http://www.fieldmarshal.comModel FMS6 FMS8 FMS10 PMV FM11 FM111 FMIV
HP/Cyl. 6/1 8/1 10/1 6/1 8/1 9.5/1 10/1
RPM 660 850 1000 660 850 950 1000
Bore 114.3 114.3 120 114.3 114.3 120 120
Stroke 130 130 130 139.7 139.7 139.7 139.7
Compression 16:1 17:1
Somewhat unique rpm rating for 6/1, shorter con rod for 6, 8, 10/1 – are these the same as the direct injected engines offered by Satyajeet? They share the unique con rod length. Other 6, 8/1’s seem “standard”.
Gangadhar Industries
http://www.gangadhar.net/diesel_engines5.htmlModel # 01 01B 01M 02 02B 02M 08 08A 08M
HP/Cyl 6/1 6/1 6/1 8/1 8/1 8/1 10/1 10/1 10/1
RPM 650 650 650 850 850 850 1000 1000 1000
Bore 114.3 114.3 114.3 114.3 114.3 114.3 120 120 120
Stroke 139.7 139.7 130 139.7 139.7 130 139.7 139.7 130
All indirect injection w/iron piston except 08A with direct injection and Al piston. All the 10/1’s and the “B” models have oil pumps. The “B” models have bushing bearings, others with TRB’s. The 10/1 “A” and “M” models have crankshaft balance weights. No other information on foundations or compression. All the 6 and 8 hp have standard piston, one with shorter con rod. 10 hp have larger piston, one with shorter con rod. Most have “ISI” but do not define the term. The company also manufacture gen sets, welders, pumps and other equipment.
GG Auto Gears
http://www.ggautomotive.com/lg_04.htm No information on website about engines.
GTC Engines
http://www.geco-trade.com/default.aspH.P./Cyl. 6/1 8/1 10/1 12/2 16/2
RPM 650 850 1000 650 850
Stroke 139.7 139.7 139.7 139.7 139.7
Fuel tank 11 11 11 15 15
Compression 18:1
Same piston and con rod except piston for the 10/1.
Hindustan Trading Corporation Liberty Diesel Engines
http://www.htcorporation.com/ HP/Cyl. 6/1 8/1 10/1 10/1LOP 10/1 CBW 12/1 14/1
RPM 650 850 1000 1000 1000 850 900
Bore 114.3 114.3 120 120 120 127 127
Stroke 139.7 139.7 139.7 139.7 139.7 139.7 139.7
Compression 18:1 Direct Injected
Bolt spacing 330x330
6/1, 8/1, 10/1 are splash lubricated, others have oil pumps. Bushing or TRB bearings available. 14/1 is Direct Injected. Two cylinder engines are said to be available, but the webpage is not present.
HP/Cyl 6/1 8/1 10/1 12/1 14/1
Bore 114.3 114.3 120 127 127
Stroke 133.3 133.3 133.3 133.3 133.3
Bolt space 305x204
Mini-Listers have different characteristics: All have TRB’s. 6/ and 8/1 are splash lubricated, others have oil pump. All have shorter stroke than “standard” listeroid. 10/1 may have Direct Injection, 14/1 is only available with Direct Injection.
All have a different foundation bolt pattern than the “standard” Listeroid. They are also lighter than the “standard”.
Hrishi Exports
http://www.hrishiexports.com/slow.htmlHP/Cyl. 6/1 8/1 10/1 12/1 14/1 12/2 16/2 20/2
RPM 650 850 1000 1000 1000 650 850 1000
Bore 114.3 114.3 120 127 127 114.3 114.3 120
Stroke 139.7 139.7 139.7 139.7 139.7 139.7 139.7 139.7
Found. Bolt Space 330x330 381x559
Fuel tank 8 8 10 10 12 12 12 12
Oil Capacity 5 5 5 5 5 7.5 7.5 7.5
All use the same con rod, only piston size varies.
http://www.indiamart.com/basantindustries/http://www.indiamart.com/indiacasting/#diesel-engineshttp://www.indiamart.com/doneria/http://www.rishabhengineering.com/diesel-engines.html#lister-diesel-enginesThese providers (manufacturers’?) provide almost no information about their engines except hp (sometimes).
JK Group of Industries JKSON engines
http://www.jksonengines.com/ltde.htm HP/Cyl. 6/1 8/1 10/1 12/2 16/2 20/2
RPM 650 850 1000 650 850 1000
Compression 18:1
Bush and TRB bearings available. Oil pumps available. Also rebranded as Power Solution (PS) by George of Utterpower and Joel. PETTER / KIRLOSKAR engines also available. Same con rod, two piston sizes.
Kirloskar
http://kirloskarapps.kirloskar.com/kirloskar/web/13$5010.html
Model KS6 KS8 KS12 KS16
HP/Cyl. 6/1 8/1 12/2 16/2
RPM 650 850 650 850
Fuel tank 11 lit. 11 lit. 15 lit 15 lit.
Compression 18:1
All engines are Direct Injection. Petter-type engines are also available. Guaranteed for 12 months against defects.
Oil cap. of 6/1 & 8/1 is 2.6 lit., smaller than “standard”. Oil cap. of others 5.7 lit. Same piston and con rod in all.
Kissan Iron
http://www.kissangroup.com/kissan_iron_works/product/lister_type.htmModel KIW- 10 1 2 7A 8 4 7 7FE 7DI 7DIH
HP/cyl. 5/1 6/1 8/1 8/1 8/1 10/1 10/1 10/1 10/1 10/1
RPM 600 650 850 950 900 1000 1000 1000 1000 1000
Bore 114.3 114.3 114.3 120 120 120 120 120 120 120
Stroke 139.7 139.7 139.7 139.7 139.7 139.7 139.7 132 139.7 139.7
Found bolt space 330X330 305X200 330X330 330X330
Fuel tank cap. 9
Model KIW- 12 12FE 14D.I.
HP/cyl. 12/1 12/1 14/1
RPM 1000 1000 1000
Bore 127 127 127
Stroke 139.7 132 139.7
Found bolt space 330x330 305x200 330x330
Fuel tank cap. 12 12 12
It appears that the DI models are direct injection and likely have aluminum pistons. Heavy flywheels are available for some models, as are water pumps. Smaller engines are splash lubricated, larger likely have pumps but it is unclear. All use the same con rod, except one 12/1. Two versions of 8/1, one with smaller piston & higher speed, one with larger piston and lower speed. 5 versions of 10/1, some with direct injection, one with smaller con rod. All the same size base casting size except KE models of 10/1 and 12/1.
Lovson
http://www.lovson.com/lister-type-slow-speed-diesel-engines.htmlModel SL-6 SL-8 SL-10 SLC10 SLC10 SLC12
/SLC Tiger Sumo Sumo
HP/cyl. 6/1 8/1 10/1 10/1 10/1 12/1
RPM 650 850 1000 1000 900 1000
Bore 114.3 114.3 120 120 127 127
Compression 16:1 16:1 17:1 17:1 17:1 17:1
Oil cap. 5 lit.
Found. Bolt space 330x330
Generally TRB main bearings, but bushing with oil pump is available. All use same con rod.
Metro/Metrex
http://www.metroexporters.com/pages/index.htmlModel ME-6 ME-8 ME-10 ME-12 ME-16 ME-20
HP/cyl. 6/1 8/1 10/1 12/2 16/2 20/2
RPM 650 850 1000 650 850 1050
Compression 18:1
All use the same piston and con rod, only rpm varies.
Mascot Enterprises
http://products.jimtrade.com/product_details.asp?ProductId=26396&SupplierId=92729No information other than a generic “Lister” picture.
Nissan Crossword Agro Industries
http://www.crosswordagro.comModel 6/1 8/1 10/1 12/1 16/1 12/2 16/2
The 12/1 is called a “Mini-Lister”, looks different from the “standard” lister types. No spec. available.
Power Anand
http://www.poweranand.com/diesel_engine.htmModel 6/1 8/1 10/1LOP 10/1CBW 12/1 12/2 16/2 20/2 24/2
RPM 650 850 1000 1000 1000 650 850 1000 1000
Bore 114.3 114.3 120 120 130 114.3 114.3 120 130
Stroke 139.7 139.7 139.7 139.7 139.7 139.7 139.7 139.7 139.7
Compression 18:1
Fuel tank 8 13
Oil cap. 5 10
Found. Bolt space 330x330 560x382
The two 10/1’s have identical spec. but different model #’s. All use the same con rod, two piston sizes.
Prakash/Fuking
http://www.prakash-india.comModel PL1 PL2 PL4 PL5
Bore 120 120 120 120
Direct or Indirect Injection. Same pistons and con rods.
Satyajeet
http://www.satyajeet.com/de2.htm GM-90 direct injection engines w/aluminum pistons
Model GM90/6 GM90/8 GM90/10 GM90/10 GM90/12 GM90/10 GM90/14
Super Sendo
RPM 750 900 1000 950 1050 800 1000
Bore 114.3 114.3 120 127 127 130 130
Stroke 130 130 130 130 130 146.5 146.5
Compression 17.5:1
Oil cap. 4.25
Found. Bolt space. 260x260
Lub. Splash plus oil pumps. Balance weights on crankshaft. Most use a similar (but shorter) con rod than “standard” The two different con rods are unique too. These engines have relatively the smallest foundation bolt spacing, except for “mini-Lister” of Hindustan Trading Corporation.
Sterling Agra
http://www.sterlingagra.comThe spec. and descriptions appear identical to Kissan Iron, found above.
Topland Group of Companies
http://www.topland-india.com/products/engine/htm/engine_1.htmModel 10A1 10A 10B 12A 12B 12ADI 14A
HP/cyl 5/1 6/1 6/1 8/1 8/1 8/1 9.5/1
Bore 114.3 114.3 114.3 114.3 114.3 114.3 114.3
RPM 600 650 650 850 850 850 1000
Model 19A 15A 15A1 15B 16A 16A1 16ASD 16ADI 16ASDI
HP/cyl 10/1 10/1 8/1 10/1 10/1 8/1 10/1 10/1 10/1
Bore 120 120 120 120 120 120 120 120 120
RPM 1000 1000 900 1000 1000 900 1000 1000 1000
Model 11A 11A1 17A 28A 28A1 29ADI 29ADI1 30ADI 30ADI1
HP/Cyl 12/1 10/1 12/1 10/1 14/1 10/1 15/1 16/1 10/1
Bore 127 127 127 127 127 127 127 130 130
Stroke 139.7 139.7 139.7 139.7 160 160 160 160 160
RPM 1000 900 1000 900 900 1000 900 1000 900
Model 18ADI 18ADI2 20A 21A 22A 23A, 24A, 25A, 25ADI, 26A, 26AI, 27ADI, 27ADI1
HP/Cyl 18/1 20/1 12/2 16/2 20/2 “Mini-listers”, all 1 cyl, 130mm stroke, 114.3, 120.
Bore 155 155 114.3 114.3 114.3 127mm bores, 6,8,10,12,14 hp, 650-1000 rpm.
Stroke 177.8 177.8 139.7 139.7 139.7 1st three indirect injection, all others direct.
RPM 750 825 650 850 1000
36(!) different models, obviously from a wide range of manufacturers. Fourteen different 10/1’s! First group has “standard” bore and stroke. Second group has “semi-standard” bore of 120 mm and standard con rod. They have a bewildering array of options, including SDM or Super Deluxe Model. Curiously, the 18/1 and 20/1 do not have an oil pump, though many of the others do. The two cylinders are all standard bore and stroke. They also have high speed (1500 rpm) water cooled diesels from 3 to 45 hp and high speed air cooled from 3 to 20 hp. Some engines are designed for marine use. Also have gen sets, alternators, & pumps. They say they are India’s largest manufacturer of engines and pumps.
Vibha
http://www.vibha.com/diesel.htmlModel 6/1 8/1 10/1 12/2 16/2 20/2
All use the same con rod, but two piston sizes.
Vidhata
http://www.vidhataindia.comModel VL5 VL6 VL7 VL8 VL9
HP/cyl. 6/1 8/1 10/1 10/1 12/1
RPM 650 850 950 1000 850
Bore 114.3 120 120 120 127
Same con rod, only piston varies.
Windsor Exports
http://www.agroengine.com/diesel1.htm#waterHP/Cyl 6/1 8/1 10/1 10/1 12/1 12/1 14/1 16/1 20/1
RPM 560 850 1000 1050 1000 650 900 850 1050
Bore 114.3 114.3 120 114.3 127 114.3 139.7 114.3 114.3
Stroke 139.7 139.7 139.7 139.7 139.7 139.7 152.4 139.7 139.7
The 6 and 8 HP are splash lubed, the rest have pumps. All have 139.7 con rods, except the 14 HP. The 14 HP has the unusual piston size of 139.7, the same as the con rod in all the others. One other manufacturer has this same combination. RPM and piston size varies considerably, but many have the “standard” 114.3 mm piston. They also have Petteroids.
