Author Topic: The Brand Roundup  (Read 216667 times)
kpgv
Re: The Brand Roundup
« Reply #60 on: March 19, 2006, 02:05:35 AM »
Hi Taeuber,
Because the thing came to me all crated up, not opened up by customs, or anyone else, and the little box inside with the extra rings, bearings, seals, manual, etc. all say "JKSON". ;D
Kevin
taeuber
    • Coppermine gallery
« Reply #61 on: March 19, 2006, 11:18:21 AM »
Hi Kevin,
yes indeed this should be seen as a proof.
Here is another web page from JKSON with the infos about there engines:
http://www.jksonengines.com/
Regards
Lars
rpg52
« Reply #62 on: March 19, 2006, 05:28:31 PM »
Hi Lars,
Because of a delivery problem, Joel called me and during the conversation stated that the engines were indeed JKSON.
Ray
binnie
« Reply #63 on: March 20, 2006, 04:45:43 AM »
I bought a 12/2 Power Solutions brand with the "Power Solutions" name moulded into the Sump door and name plate attached...but the machine is a JKSON by make from the manufacturer. In other words what I understand is that JKSON mfgs them for Geo according to his stipulations and puts his brand name on them. It does have the Brass Idler gear stipulated by Geo., and the sump was clean when I inspected it. They look good & the moulding seem superior. Now lets see how they run.
It will be some time till I get this thing up & running...need to pour the base and we are still knee-deep in snow up here. Will let you know.
taeuber
« Reply #64 on: March 23, 2006, 10:16:43 AM »
rpg52
« Reply #65 on: March 24, 2006, 01:17:13 AM »
Added manufacturers thanks to Lars.
“Standard”:  114.3 piston, 139.7 con rod.  Con rods go from 130 to 177.8.  Other common pistons are 120, 127 and 130.  Materials are mostly iron, few aluminum.  330x330 mm foundation bolt for 1 cyl., 381x559 for 2 cyl., some variation.
Ammerajkot          http://www.ameerrajkot.com
H.P.             5   6       8    10   12      14   14
Cylinder             1
Bore in MM          114.3      114.3   120 127      152.4 130
Stroke in MM          139.7      139.7   139.7      177.8 147
Speed RPM          600 650       850   1000       650 1000
Compression Ratio          1:18
Lub. Oil Consumption Capacity (Lit.)    4.5         4.5      5.0
Foundation Bolt Spacing in MM    330 x 330
Fuel Tank Capacity (Lit.)       14.0      14.0   14.0      14.0
The 14/1’s are two versions, one with larger piston & longer stroke but lower speed, the other with smaller piston, shorter stroke but higher speed.  These engines and Ampro use the unusual 152.4x177.8 piston & con rod in their 14/1 and 16/1.
They also offer what appears to be direct injection engines (“New Variety”), similar to (or the same?) as Satyajeet GM-90.
Ampro Exports      http://www.amproexports.com/lister-diesel-engines.html
Particulars    6/1    8/1    10/1    12/1    14/1    16/1    12/2    16/2    20/2
Horse Power    6    8    10    12    14    16    12    16    20
RPM       650    850    1000    1000    850    850    650    850    1000
Bore       114.3   114.3   120   127   152.4   152.4   114.3   114.3   120
Stroke       139.7   139.7   139.7   139.7   177.8   177.8   139.7   139.7   139.7
Bolt spacing   330 x 330            356 x 356      381 x 559
Fuel Cap.(Lit.)   8   8   10   10   12   12   12   12
Lub. Oil Cap.   5   5   5   5   7.5   7.5   7.5   7.5   13
These all use the same con rod, except the 14/1 and 16/1.  Piston size and rpm varies.
Aswamegh      http://www.indiamart.com/ashwamegh/#diesel-engine
H.P.      6   8   10   12   12   14   15   16   20   20
RPM      650   850   1050   1000   650   1000   1000   850   1050   1000
Cylinder      1   1   1   1   2   1   1   2   2   2
Bore      114.3   114.3   114.3   114.3   114.3   130   130   114.3   114.3   120
Stroke      139.7   139.7   139.7   146.05   139.7   139.7   145   160   139.7   139.7
Compression ratio:  18:1, except 14/1 and 15/1 which are 16.5:1.  They are Direct Injection engines.
All 2 cylinders have bush main bearings and oil pump, can be ordered with taper roller bearing.  6/1 and 8/1 are splash only, but can be ordered with oil pump.  All use the same piston except 14/1, 16/1 and 20/2.  Con rod varies.
Atul Group   http://www.atulgroup.com
HP   6/1   8/1   10/1   12/1
Bore   114   120   120   127
Stroke   139.6   139.6   139.6   139.6
All use the same con rod, but it is 0.1mm shorter than the standard.  Is it really different or not?
Field Marshall http://www.fieldmarshal.com
Single and double cylinder 5 to 20 hp, 600 to 1000 rpm, no other info.
GG Auto Gears   http://www.ggautomotive.com/lg_04.htm
No information on website about engines.
GTC Engines   http://www.geco-trade.com/default.asp
H.P./Cyl.   6/1   8/1   10/1   12/2   16/2
RPM   650   850   1000   650   850
Bore   114.3   114.3   120   114.3   114.3
Stroke   139.7   139.7   139.7   139.7   139.7
Fuel tank   11   11   11   15   15
Compression  18:1
Same piston and con rod except piston for the 10/1.
Hindustan Trading Corporation    Liberty Diesel Engines   http://www.htcorporation.com/
HP/Cyl.      6/1   8/1   10/1   10/1LOP   10/1 CBW   12/1   14/1
RPM      650   850   1000   1000   1000      850   900
Bore      114.3   114.3   120   120   120      127   127
Stroke      139.7   139.7   139.7   139.7   139.7      139.7   139.7
Compression   18:1                     Direct Injected
Bolt spacing   330x330
6/1, 8/1, 10/1 are splash lubricated, others have oil pumps.  Bushing or TRB bearings available. 14/1 is Direct Injected.  Two cylinder engines are said to be available, but the webpage is not present.
Hindustan Trading Co. “Mini-Listers”
HP/Cyl      6/1   8/1   10/1   12/1   14/1
Bore      114.3   114.3   120   127   127
Stroke      133.3   133.3   133.3   133.3   133.3
Bolt space   305x204
Mini-Listers have different characteristics:  All have TRB’s.  6/ and 8/1 are splash lubricated, others have oil pump.  All have shorter stroke than “standard” listeroid.  10/1 may have Direct Injection, 14/1 is only available with Direct Injection.
All have a different foundation bolt pattern than the “standard” Listeroid.  They are also lighter than the “standard”.
Hrishi Exports   http://www.hrishiexports.com/slow.html
HP/Cyl.      6/1   8/1   10/1   12/1   14/1   12/2   16/2   20/2
RPM      650   850   1000   1000   1000   650   850   1000
Bore      114.3   114.3   120   127   127   114.3   114.3   120
Stroke      139.7   139.7   139.7   139.7   139.7   139.7   139.7   139.7
Found. Bolt Space    330x330            381x559
Fuel tank      8   8   10   10   12   12   12   12
Oil Capacity   5   5   5   5   5   7.5   7.5   7.5
All use the same con rod, only piston size varies.
JK Group of Industries  JKSON engines      http://www.jksonengines.com/ltde.htm
HP/Cyl.      6/1   8/1   10/1   12/2   16/2   20/2
RPM      650   850   1000   650   850   1000
Bore      114.3   114.3   120   114.3   114.3   120
Compression   18:1
Bush and TRB bearings available.  Oil pumps available.  Also rebranded as Power Solution (PS) by George of Utterpower and Joel.  PETTER / KIRLOSKAR engines also available.
Kirloskar      http://kirloskarapps.kirloskar.com/kirloskar/web/13$5010.html
Model      KS6   KS8   KS12   KS16
HP/Cyl.      6/1   8/1   12/2   16/2
RPM      650   850   650   850
Fuel tank      11 lit.   11 lit.   15 lit   15 lit.
Compression   18:1
All engines are Direct Injection.  Petter-type engines are also available.  Guaranteed for 12 months against defects.
Kissan Iron     http://www.kissangroup.com/kissan_iron_works/product/lister_type.htm
Model   KIW-   10   1   2   7A   8   4   7   7FE   7DI    7DIH
HP/cyl.      5/1   6/1   8/1   8/1   8/1   10/1   10/1   10/1   10/1   10/1
RPM      600   650   850   950   900   1000   1000   1000   1000   1000
Bore      114.3   114.3   114.3   120   120   120   120   120   120   120
Stroke      139.7   139.7   139.7   139.7   139.7   139.7   139.7   132   139.7   139.7
Found bolt space   330X330                     305X200   330X330   330X330
Fuel tank cap.   9
Model   KIW-   12   12FE   14D.I.
HP/cyl.      12/1   12/1   14/1
RPM      1000   1000   1000
Bore      127   127   127
Stroke      139.7   132   139.7
Found bolt space   330x330   305x200   330x330
Fuel tank cap.   12   12   12
It appears that the DI models are direct injection and likely have aluminum pistons.  Heavy flywheels are available for some models, as are water pumps.  Smaller engines are splash lubricated, larger likely have pumps but it is unclear.   All use the same con rod, except one 12/1.    All the same size base casting size except one 10/1 and one 12/1.
Lovson   http://www.lovson.com/lister-type-slow-speed-diesel-engines.html
Model      SL-6   SL-8   SL-10    SLC10   SLC10   SLC12
            /SLC   Tiger   Sumo   Sumo
HP/cyl.      6/1   8/1   10/1   10/1   10/1   12/1
RPM      650   850   1000   1000   900   1000
Bore      114.3   114.3   120   120   127   127
Compression   16:1   16:1   17:1   17:1   17:1   17:1
Oil cap.      5 lit.
Found. Bolt space   330x330
Generally TRB main bearings, but bushing with oil pump is available.
Metro/Metrex   http://www.metroexporters.com/pages/index.html
Model      ME-6   ME-8   ME-10   ME-12   ME-16   ME-20
HP/cyl.      6/1   8/1   10/1   12/2   16/2   20/2
RPM      650   850   1000   650   850   1050
Bore      114.3   114.3   114.3   114.3   114.3   114.3
Compression   18:1
All use the same piston and con rod, only rpm varies.
Mascot Enterprises   http://products.jimtrade.com/product_details.asp?ProductId=26396&SupplierId=92729
No information other than a generic “Lister” picture.
Nissan   Crossword Agro Industries   http://www.crosswordagro.com
Model      6/1   8/1   10/1   12/1   16/1   12/2   16/2
The 12/1 is call a “Mini-Lister”, looks different from the “standard” lister types.  No spec. available.
Power Anand   http://www.poweranand.com/diesel_engine.htm
Model      6/1   8/1   10/1LOP   10/1CBW   12/1   12/2   16/2   20/1   24/2
RPM      650   850   1000   1000   1000   650   850   1000   1000
Bore      114.3   114.3   120   120   130   114.3   114.3   120   130
Stroke      139.7   139.7   139.7   139.7   139.7   139.7   139.7   139.7   139.7
Compression   18:1
Fuel tank      8               13
Oil cap.      5               10
Found. Bolt space    330x330               560x382
The two 10/1’s have identical spec. but different model #’s.  All use the same con rod.
Prakash/Fuking   http://www.prakash-india.com
I could only find Petter-type engines on their website.
Satyajeet   http://www.satyajeet.com/de2.htm      GM-90 direct injection engines w/aluminum pistons
Model      GM90/6   GM90/8   GM90/10   GM90/10   GM90/12   GM90/10   GM90/14
               Super      Sendo
RPM      750   900   1000   950   1050   800   1000
Bore      114.3   114.3   120   127   127   130   130
Stroke      130   130   130   130   130   146.5   146.5
Compression   17.5:1
Oil cap.      4.25
Found. Bolt space.   260x260
Lub. Splash plus oil pumps.  Balance weights on crankshaft.  Most use a similar (but shorter) con rod than “standard” The two different con rods are unique too.  These engines have the smallest foundation bolt spacing of any listed.
Sterling Agra   http://www.sterlingagra.com
The spec. and descriptions appear identical to Kissan Iron, found above.
Vibha   http://www.vibha.com/diesel.html
Model      6/1   8/1   10/1   12/2   16/2   20/2
Vidhata   http://www.vidhataindia.com
Model   VL5   VL6   VL7   VL8   VL9
HP/cyl.   6/1   8/1   10/1   10/1   12/1
RPM   650   850   950   1000   850
Bore   114.3   120   120   120   127
Joe
« Reply #66 on: March 24, 2006, 12:25:15 PM »
rpg52,
A lot of work has gone into compiling/maintaining this info - Thanks....
Joe
Nothing is easy...if it were...anybody could do it.
2005 Power Solutions  6/1-ST5
SHIPCHIEF
« Reply #67 on: March 24, 2006, 11:56:18 PM »
I'm not seeing the 20/1 on the Poweranand site. I thought that was a Satyajeet, but it didn't see it the either?
Say Dirtbikepilot, Where did yours come from?
Scott E
Ashwamegh 25/2 & ST12
rpg52
« Reply #68 on: March 25, 2006, 12:07:41 AM »
Shipchief,
I think it was a typo, I only see a 20/2 on Poweranand too.  Corrected for next iteration.
Ray
rpg52
« Reply #69 on: March 25, 2006, 12:40:39 AM »
Everyone,
I have gone to the various manufacturer’s websites and assembled the following from their information.  Some provide a lot of useful information, one provided a table of numbers with no labels as to what the numbers meant!  None of them talk about sand in the sump.  Some mention balance.  It seems that the bore and stroke imply the degree of standardization between engines, which I thought might be useful.  A few use the same piston and con rod in all their engines, others only vary the piston.  A few change both.  The dimensions of the foundation bolts, which may not be particularly useful in itself, would tend to indicate whether a different casting is used for the base.
 “Standard”:  114.3 piston, 139.7 con rod.  Con rods go from 130 to 177.8.  Other common pistons are 120, 127 and 130.  Materials are mostly iron, few aluminum.  330x330 mm foundation bolt for 1 cyl., 381x559 for 2 cyl., some variation.  5/1, 6/1 and 8/1 are often the same engine, only with an increase in rpm from 600, 650 to 850 (and likely with smaller diameter, heavier flywheels).
Other observations:  14/1 and 16/1 are most often made from odd sized or “non-standard” pistons or con rods.  Oil capacities are not given for many of the engines, but the Kirloskar capacities are about half that of other manufacturer’s.  The Hindustan Trading Co. “Mini-Listers” appear to be a considerably different design than that offered by others.  The piston sizes are “standard” but the con rod and foundation bolt patterns are different than any other engines.
Hope this is helpful, it was to me.  :)
H.P./Cyl.             5/1   6/1       8/1    10/1   12/1   14/1   14/1
H.P./Cyl      6/1   8/1   10/1   12/1   12/2   14/1   15/1   16/2   20/2   20/2
Crossword Agro Industries   http://www.crosswordagro.com/english/ssde.htm
HP/Cyl.      6/1   8/1   10/1   12/1   12/2   16/1   12/2   16/2
See Nissan engines below.
Model      FMS6   FMS8   FMS10   PMV   FM11   FM111   FMIV
HP/Cyl.      6/1   8/1   10/1   6/1   8/1   9.5/1   10/1
RPM      660   850   1000   660   850   950   1000
Bore      114.3   114.3   120   114.3   114.3   120   120
Stroke      130   130   130   139.7   139.7   139.7   139.7
Compression   16:1         17:1
Compression  18:1
Bolt space   305x204
Compression   18:1
RPM      650   850   650   850
Compression   18:1
Oil cap. 6/1 & 8/1 2.6 lit., smaller than “standard”.  Oil cap. of others 5.7 lit.
Fuel tank cap.   9
RPM      1000   1000   1000
Bore      127   127   127
It appears that the DI models are direct injection and likely have aluminum pistons.  Heavy flywheels are available for some models, as are water pumps.  Smaller engines are splash lubricated, larger likely have pumps but it is unclear.   All use the same con rod, except one 12/1.    All the same size base casting size except one 10/1 and one 12/1 (KE models).
Oil cap.      5 lit.
Compression   18:1
Model      6/1   8/1   10/1LOP   10/1CBW   12/1   12/2   16/2   20/2   24/2
Compression   18:1
Fuel tank      8               13
Oil cap.      5               10
Model      PL1   PL2   PL4   PL5
Bore      120   120   120   120
Stroke      139.7   138.7   139.7   139.7
Direct or Indirect Injection.
               Super      Sendo
Compression   17.5:1
Oil cap.      4.25
« Reply #70 on: April 10, 2006, 03:35:07 AM »
I have enver heard of these fellows but they have Petters and even a triple petter.
http://www.indiamart.com/htc
BTW:
Prakash has added a new high speed clone to the line up something like a Yanmar. Is the twilte of the Listeriod is upon us????
http://www.indiamart.com/basantindustries/
http://www.indiamart.com/indiacasting/#diesel-engines
http://www.indiamart.com/doneria/
http://www.rishabhengineering.com/diesel-engines.html#lister-diesel-engines
Interesting mix of companies many I've never seen in the brand round up...
« Last Edit: April 10, 2006, 03:49:09 AM by Doug »
rpg52
« Reply #71 on: June 04, 2006, 01:07:18 AM »
May ’06 iteration, some corrections, etc.
Other observations:  14/1 and 16/1 are most often made from odd sized or “non-standard” pistons or con rods.  Oil capacities are not given for many of the engines, but the Kirloskar capacities are about half that of other manufacturer’s for the 6/1 & 8/1.  The Hindustan Trading Co. “Mini-Listers” appear to be a considerably different design than that offered by others.  The piston sizes are “standard” but the con rod and foundation bolt patterns are different than any other engines.  Direct Injection implies a different head design than “standard”, and may have an aluminum piston.
Bore in MM          114.3      114.3   120    127   139.7 130
Stroke in MM          139.7      139.7   139.7   139.7   152.4 147
Lub. Oil Capacity (Lit.)       4.5               5.0
The 14/1’s are two versions, one with larger piston & longer stroke but lower speed, the other with smaller piston, shorter stroke but higher speed.  The 14/1’s use unusual piston and con rod’s.  I wonder if there was a typo in their spec. sheet – why would they use a piston exactly the same size as a standard con rod?
Bolt spacing   330 x 330            14, 16=356 x 356      2 cyl. = 381 x 559
These all use the same con rod, except the 14/1 and 16/1.  Piston size and rpm varies.  Ampro uses the unusual 152.4x177.8 piston & con rod in their 14/1 and 16/1.  They also offer what appear to be direct injection engines (“New Variety”), similar to (or the same?) as Satyajeet GM-90 in 6, 8, 10, & 12/1 models.  Check out their toilets (water closets)!
All 2 cylinders have bush main bearings and oil pump, can be ordered with taper roller bearing.  6/1 and 8/1 are splash only, but can be ordered with oil pump.  Same piston except 14/1, 16/1 and 20/2.  Con rod the same except 12/1, 15/1 & 16/2.
Somewhat unique rpm rating for 6/1, shorter con rod for 6, 8, 10/1 – are these the same as the direct injected engines offered by Satyajeet?  They share the unique con rod length.   Other 6, 8/1’s seem “standard”.  This is the only 9.5/1 offered by any manufacturer.
Compression  18:1
Bolt space   305x204
These providers (manufacturers’?) provide almost no information about their engines except hp (sometimes).
Compression   18:1
Bush and TRB bearings available.  Oil pumps available.  Also rebranded as Power Solution (PS) by George of Utterpower and Joel.  PETTER / KIRLOSKAR engines also available.  Same con rod, two piston sizes.
RPM      650   850   650   850
Compression   18:1
Oil cap. of 6/1 & 8/1 is 2.6 lit., smaller than “standard”.  Oil cap. of others 5.7 lit.  Same piston and con rod in all.
Fuel tank cap.   9
RPM      1000   1000   1000
Bore      127   127   127
It appears that the DI models are direct injection and likely have aluminum pistons.  Heavy flywheels are available for some models, as are water pumps.  Smaller engines are splash lubricated, larger likely have pumps but it is unclear.   All use the same con rod, except one 12/1.    All the same size base casting size except KE models of 10/1 and 12/1.
Oil cap.      5 lit.
Generally TRB main bearings, but bushing with oil pump is available.  All use same con rod.
Compression   18:1
The 12/1 is called a “Mini-Lister”, looks different from the “standard” lister types.  No spec. available.
Compression   18:1
Fuel tank      8               13
Oil cap.      5               10
The two 10/1’s have identical spec. but different model #’s.  All use the same con rod, two piston sizes.
Direct or Indirect Injection.   Same pistons and con rods.
               Super      Sendo
Compression   17.5:1
Oil cap.      4.25
Lub. Splash plus oil pumps.  Balance weights on crankshaft.  Most use a similar (but shorter) con rod than “standard” The two different con rods are unique too.  These engines have relatively smallest foundation bolt spacing, except for “mini-Lister” of Hindustan Trading Corporation.
All use the same con rod, but two piston sizes.
Same con rod, only piston varies.
fattywagonman
« Reply #72 on: July 10, 2006, 03:28:24 PM »
I havn't seen these guys on the list...
http://www.gangadhar.net/diesel_engines5.html
taeuber
« Reply #73 on: July 10, 2006, 04:54:36 PM »
Hi fattywagonman,
this seller seems to sell the same engines like this one:
http://www.topland-india.com/products/engine/htm/engine_1.htm
Bye
Lars
rpg52
« Reply #74 on: July 10, 2006, 08:22:35 PM »
July ’06 iteration, included two more manufacturer’s.
H.P./ Cyl     6/1    8/1    10/1    12/1    14/1    16/1    12/2    16/2    20/2
These all use the same con rod, except the 14/1 and 16/1.  Piston size and rpm varies.  Ampro uses the unusual 152.4x177.8 piston & con rod in their 14/1 and 16/1 – these engines also have an unusual size of foundation bolt pattern.  They offer what appear to be direct injection engines (“New Variety”), similar to (or the same?) as Satyajeet GM-90 in 6, 8, 10, & 12/1 models.  Check out their toilets (water closets)!
Gangadhar Industries  http://www.gangadhar.net/diesel_engines5.html
Model #   01   01B   01M   02   02B   02M   08   08A   08M
HP/Cyl   6/1   6/1   6/1   8/1   8/1   8/1   10/1   10/1   10/1
RPM   650   650   650   850   850   850   1000   1000   1000
Bore   114.3   114.3   114.3   114.3   114.3   114.3   120   120   120
Stroke   139.7   139.7   130   139.7   139.7   130   139.7   139.7   130
All indirect injection w/iron piston except 08A with direct injection and Al piston.  All the 10/1’s and the “B” models have oil pumps.  The “B” models have bushing bearings, others with TRB’s.  The 10/1 “A” and “M” models have crankshaft balance weights.    No other information on foundations or compression.  All the 6 and 8 hp have standard piston, one with shorter con rod.  10 hp have larger piston, one with shorter con rod.  Most have “ISI” but do not define the term.  The company also manufacture gen sets, welders, pumps and other equipment.
Compression  18:1
Bolt space   305x204
Compression   18:1
RPM      650   850   650   850
Compression   18:1
Fuel tank cap.   9
RPM      1000   1000   1000
Bore      127   127   127
It appears that the DI models are direct injection and likely have aluminum pistons.  Heavy flywheels are available for some models, as are water pumps.  Smaller engines are splash lubricated, larger likely have pumps but it is unclear.   All use the same con rod, except one 12/1.    Two versions of 8/1, one with smaller piston & higher speed, one with larger piston and lower speed.  5 versions of 10/1, some with direct injection, one with smaller con rod.   All the same size base casting size except KE models of 10/1 and 12/1.
Oil cap.      5 lit.
Compression   18:1
Compression   18:1
Fuel tank      8               13
Oil cap.      5               10
               Super      Sendo
Compression   17.5:1
Oil cap.      4.25
Lub. Splash plus oil pumps.  Balance weights on crankshaft.  Most use a similar (but shorter) con rod than “standard” The two different con rods are unique too.  These engines have relatively the smallest foundation bolt spacing, except for “mini-Lister” of Hindustan Trading Corporation.
Topland Group of Companies   http://www.topland-india.com/products/engine/htm/engine_1.htm
Model      10A1   10A   10B   12A   12B   12ADI   14A
HP/cyl      5/1   6/1   6/1   8/1   8/1   8/1   9.5/1
Bore      114.3   114.3   114.3   114.3   114.3   114.3   114.3
RPM      600   650   650   850   850   850   1000
Model      19A   15A   15A1   15B   16A   16A1   16ASD   16ADI   16ASDI
HP/cyl      10/1   10/1   8/1   10/1   10/1   8/1   10/1   10/1   10/1
Bore      120   120   120   120   120   120   120   120   120
RPM      1000   1000   900   1000   1000   900   1000   1000   1000
Model      11A   11A1   17A   28A   28A1   29ADI   29ADI1   30ADI   30ADI1
HP/Cyl      12/1   10/1   12/1   10/1   14/1   10/1   15/1   16/1   10/1
Bore      127   127   127   127   127   127   127   130   130
Stroke      139.7   139.7   139.7   139.7   160   160   160   160   160
RPM      1000   900   1000   900   900   1000   900   1000   900
Model      18ADI   18ADI2
HP/Cyl      18   20
Bore      155   155
Stroke      177.8   177.8
RPM      750   825
28(!) different models, obviously from a wide range of  manufacturers.  Eleven different 10/1’s!  First group has “standard” bore and stroke.  Second group has “semi-standard” bore of 120 mm and standard con rod.  They have a bewildering array of options, including SDM or Super Deluxe Model.  Curiously, the 18/1 and 20/1 do not have an oil pump, though many of the others do.  They say they are India’s largest manufacturer of engines and pumps.
