Author Topic: Lister identification required.  (Read 3864 times)
trebby67
« on: December 01, 2006, 06:36:34 PM »
Hi, I have a lister which I believe is an ST1 the number is 4319ST130-06 I would be grateful if anyone can supply me with details of this engine, Horse power age and anything else that may be relevant .
Re: Lister identification required.
« Reply #1 on: December 02, 2006, 03:34:31 AM »
The ST1 is a great little engine. 4319ST130-06
bore/stroke 3.75 x 3.5
0.63 liter displacement
BHP continuous
8.1 @ 2000rpm
7.3 @ 1800rpm
6.0 @ 1500rpm
4.7 @ 1200rpm
fuel consumption at full load - 0.405 at 1800 and 1200 rpm
Yours is originally a 50hz 1500rpm genset build.
let me know if you need manuals or parts for this machine, our stock is very comprehensive for these.
Gary
diesel-electric.us
trebby67
« Reply #2 on: December 02, 2006, 01:08:43 PM »
Hi,
 garry thanks for the help.
Would this run a 5 KVA generator running at 1500RPM 220 Volts ?
« Reply #3 on: December 02, 2006, 09:19:38 PM »
Sounds like a proper combination although you may not realize a full 5KVA at 1500. Condition and tune on your engine has a lot to do with actual output and the ratings listed are ideal numbers. From experience, I would expect to get between 4 and 4.5 kW out of an average ST1. An oversized head will add a bit of protection against overload as you will be limited by horsepower rather than winding capacity.
Gary
diesel-electric.us
trebby67
« Reply #4 on: December 03, 2006, 03:38:01 PM »
Thanks Garry, you have been most helpfull.
