Don't forget to check out the LEF Gallery! Exclusively for LEF members, an ideal alternative to Photobucket, Flickr, etc. It's FREE, and best of all totally AD FREE! Just click the link!
I'd love to see these working for a living - and it's only the next state over. Unfortunately, It's all the way diagonally across ohio from here after driving through pennsylvania for an hour.Maybe the next time I decide to go to the AF museum I can stop in - that would be a much more manageable drive.I really am a babe in the woods about these big generator systems. 300 amps @ 125 V just to excite the field!
Hello Petter:Verry nice pictures....I can't speak for the US electrical industry or even Canadian surface plant standards but in my little corner of the trades 2300 v power systems were actualy common 30 and 40 years ago. We still have pumps running on 2300, infact I spent 6 hours having a heart to heart with pair of 500 hp dewatering pumps that refused to restart after shut down.2300 is still nice because you don't need stress cones at the terminations. Later we moved on to 4160 still nice because the terminations are easy, 6900 followed and 13.8 kv became the new standard.But in the early days it wasn't uncommon to see 2300v non armoured portable power cables strung up in some areas feeding the first generation portable substations, and later we even have sheilded 6900 v cable hanging in some drifts.Today this all has been replaced with higher voltages for greater efficiency and hi voltage Tech cable for safety.Personaly I like the 4160 and the small 600 kVA subs easy to set up and the higher reactance of the tranformer and lines keep fault currents low as compared to the new 1333 portables and the monster switch room subs with their 13.8 feeds. The arc flash suits in high heat make you wish for the old days too.Doug
Electric trucks suck!Trains are so cool!Doug
