in a technical sense a lister/oid is not a machine in that by itself it produces no useful work
when coupled to a generator or a pump it now becomes part of a machine that does useful work
the reason i asked the question was based on research and what i found on the evolution of engineering as it pertains to
rigidly mount a machine
years ago it was customary to mount machines that were stationary directly to a concrete base, these machines had to be designed quite heavy because of the fact that all forces imparted on or into the concrete base were returned in amount equal to the original source or in some instances amplified and returned to the machine. as long as machines are built heavy they can and did survive very well on rigid mounts, the problem now is machines are built lighter by design and necessity.
lighter vibrating machines if rigidly mounted cannot handle these forces being returned to the machine by rigid mounting, parts fail do to fatigue. resilient mounts when properly engineered and implimented reduce by absorbing these forces from being reintroduced to the machine, and in doing so allow the engineers to reduce the physical size and strength of some of the components and in the end reduce costs.
bottom line is that there is no reason to believe that proper resilient mounts will be destructive to a machine that was originally designed to stand up to rigid mounting, if anything proper engineered resilient mounts should increase the lifespan of the machine.
also it should be stated that other component that make a lister/oid a machine such as a compressor, generator or pump, will benefit from the machine not being rigidly mounted, having stresses and vibration returned from the concrete base to the machine while not being detrimental to the lister/oid can and in many cases are destructive to these other components. it should be taken into consideration that the generator, pump, compressor etc have been balanced and provisions should be made to reduce or eliminate other sources of stress, vibration etc from being introduced to them.
i have come to these conclusions from not what i have been told, what i have been led to believe or what i feel. Rather i have come to these conclusion thru much research from multiple sources and multiple types of equipment and design. while it may be said that these other types of engines and equipment are not lister/oids, it really makes no difference, lister/oids are not atypical in design.
i also realize folks are going to mount their engines any way they so choose, and i will as well. my only point here is to raise question and to find answers to these questions and provide alternatives to those that want to think about them. some of you will think about it, some will blow it off, and the rest will have their eyes glaze over.
who knows there might be someone reading all of this who actually works as an engineer, designing mounting systems for stationary engine's, perhaps he/she will find their way here and step up and say a few words.
