Bio:
please take this for how it is intended, i am not trying to be critical, but we know what happens in a fire.
you need to cease using this unit until you install a suitable fuel line from your fuel tank!
copper as a fuel line is ok i guess if adequately supported.
copper will work harden, crack/leak or completely break off at one of the fittings and dump a flame accellerant all over your engine room.
i loop in the copper will help, but will not eliminate the risk, it may prolong the lifespan, but fail it will.
with the tank mounted high it will gravity feed till dry,
better to go with synflex (tm) which is a thermoplastic, used for truck air lines as well as fuel lines. but in a fire it will melt and add to the problem
or go with a single braid fuel line such as stratoflex (tm) which is also used in truck air and fuel lines
synflex is cheap, and it works
stratoflex is relatively expensive and it also works
neither will fail due to work hardening
please replace the copper line
