I put a battery on it last weekend to see if it would turn over, but no luck. So I pull it off and open it up, water got into it the armature so I cleaned everything up and put it back together, now it turns over when I put power to it.
I hooked up the fuel line and tried to purge the air out but I might be doing something wrong. The hand pump doesn't have a lot of resistance but I cracked the inlet line on the fuel filter and I was able to pump fuel out of it. I cracked a plug on one of the discharge ports on the filter housing and pumped like mad, but all I got was an slight dribble and bubbles. I tightened the plug down and continued to pump, but nothing came out of the bleeder port.
After nearly wearing out my thumb I cranked the engine over and I was getting a little bit of smoke, but only a wisp.
Can anyone give me a rough idea how much pumping would be needed to purge the air out of the filter?
I'm wondering if I have a weak supply pump that can't build enough pressure to overcome the bleeder valve thus making it impossible to purge the air, or I could just be doing it wrong. All my knowledge is with Mercedes diesels and they are a very different beast compared to this Lister.
Thanks,
Jason
