Author Topic: minipetter parts  (Read 7021 times)
ronsmith
    • Bentleybranch studio
minipetter parts
« on: October 14, 2006, 10:18:58 PM »
Does anyone know where I can get a rocker box cover gasket and an o-ring for the fuel injector for my 3.5 minipetter? I tried George but no luck.
Re: minipetter parts
« Reply #1 on: October 15, 2006, 01:54:41 AM »
You may need to make the gasket, not hard but use Cork....
The copper washer you want, find a Bosche dealer that rebuilds injection pumps, the one I deal with here in Sudbury seems to be able to fabricate or find anypart even stuff that isn't Bosche.
Check your decompressor handle for an O ring that fits in the groove near the handle end. If its Missing thats a Cat part ( Or rather I found a perfect match in CAT O ring spares kit. But its probably a standard size ring. )
I don't know how big a mini Petter rocker box cover gasket is but I have a spare for big Petter. Post rough guess measurements and I'll see If it the same and Maybe I can copy it or part with it....
ronsmith
« Reply #2 on: October 15, 2006, 02:59:20 AM »
The o-ring I need goes around the injector shaft in a groove about halfway down the shaft and the the shaft slides down into the injector hole. I guess it makes and airtight seal around the injector shaft.
« Reply #3 on: October 15, 2006, 03:25:07 AM »
Can you give me the MICO part number on the Injector?
If Heinneger can get the ring or match it up to my spare injector ( provided yours is the same as mine ). I'll get a quote for the parts and PM you....
ronsmith
« Reply #4 on: October 15, 2006, 11:25:31 PM »
the number on my injector is 9430031258    elic bosh 486      That was what was written on the injector.
« Reply #5 on: October 15, 2006, 11:45:09 PM »
Same injector as my spare....
Wednesday I'm off work and time permitting I'll see if I can get a Bosch part or number of a part you can track.
ronsmith
« Reply #6 on: October 17, 2006, 12:30:34 AM »
Thanks Doug, I might also need a injector tip. Mine is only spraying out of two of the jets. Seems like it should be spraying out three ?
« Reply #7 on: October 17, 2006, 01:19:00 AM »
I don't know about the spray pattern I can't even see the holes....
ronsmith
« Reply #8 on: October 18, 2006, 01:48:31 PM »
Doug, Would you know the torque setting on the 4 head bolts on the 3.5hp minipetter? the bolts measure about 1/2" diameter and it takes a 19mm socket to remove the nuts on them.
rcavictim
« Reply #9 on: October 18, 2006, 02:24:24 PM »
Ron,
`m gonna take an edumedicated guess at 65 (sixty-five) foot pounds.  Sorry about not answering this question on your other post, I got distracticated.
-Changfa 1115
-Want Lister 6/1
« Reply #10 on: October 18, 2006, 10:01:02 PM »
I have torque settings for the head bolts for the Big Petter but in metric and I haven't converted back yet...
I can't get my head bolts to budge so I assume the torque is mind bending...
Bad day, after 3 weeks of tinkering my Gib key is getting ugly. I haven't enough room for any sort of puller.
The Key is soft and the marks from its setting lead me to believe some force was used to set it ( to say the least
Stripped 4 studs for my Rocker Box trying to get access to pul the head.
5/16 W bolts are $4.00 a piece
ronsmith
« Reply #11 on: October 18, 2006, 11:46:10 PM »
I have my minipetter torqued to 90lbs now but it still weeps a little antifreeze around the bolts. When I got it brand new it was weeping coolant around the bolts. Im going to take off the head this weekend and clean the valves and ports. Possibly regrind the valves.
« Reply #12 on: October 19, 2006, 01:23:21 AM »
No fear of coolant weeping on mine.
I don't think I've ever seen 4 nuts screwed so tight in my life.
My head checked out flat, but I took the option to cut new seats as insurance...
I just wish I could swap the heads out...
ronsmith
« Reply #13 on: November 04, 2006, 10:45:32 PM »
Does anyone know where I can buy a fuel injector nozzle for my minipetter 3.5 hp. the part number on the old one is...9430031258   e lic bosh 486 india  . Also can my old one be dissembled? The old one is down to only one jet spraying and I have soaked it in acetone and blew air into it but it wont unclog. Engine wont start on one spray.  :(
« Reply #14 on: November 05, 2006, 03:27:47 AM »
Peter says of you change the first digit 9 to a zero this will cross reference to a Bosch number...
