I don't have one but have a friend that does, in a gen set. Runs good, reasonable build, the only caveat I would make is to straight away mount the radiator off the frame. As is it shakes more than I would care to see long term. Four rubber shock mounts solved that problem. But you have to need a fair amount of power to keep a 25K set loaded up to the power range it should run.
