Author Topic: kill-a-watt meter from who,what,when where?  (Read 5731 times)
buickanddeere
« on: September 29, 2006, 07:55:54 PM »
  I must be doing something wrong. Searches for the kill-a-watt meters occassionally seen on this site all show instead just the little 15A U-Ground P-4400 or something gizmo.
  Could somebody please post a link or something for factory data and dealers of these meters please?
jimmer
Re: kill-a-watt meter from who,what,when where?
« Reply #1 on: September 29, 2006, 08:10:24 PM »
The P4400 is the only model that I know of.
jim
Chaz
1950 Lister CS 3 1/2 - 1
buickanddeere
« Reply #3 on: October 24, 2006, 03:46:57 AM »
  That's just the little rinky dinky 120V u-ground kill-a-watt meter.
 What I'm thinking of is the wall mounted box that shows current, volts and frequency on standard analog gauges. These units will handle a 15kva gen set's output.
Andre Blanchard
« Reply #4 on: October 24, 2006, 01:25:07 PM »
http://www.submetering4less.com/
http://www.cetsolar.com/metersackwhrs.htm
http://michaelbluejay.com/electricity/measure.html
http://www.testequipmentdepot.com/amprobe/kwh/kwhmeters.htm
http://www.hoytmeter.com/transducers/multitran/kwh/kwh.html
About one minute with Google.
If that's what you want I would just get some panel meters and mount them in a box.
______________
Andre' B
buickanddeere
« Reply #5 on: October 24, 2006, 05:32:04 PM »
   Thanks,that's what I was prety much looking for. I had tried my previous searches with kill-a-watt always in the text.
  The eum-2000 etc looks like it should work.
   A look through the Electrosonic cataloge did show an abundance or 0-120V and 0-5 amp meters plus the appropriate CT's and PT's, frequency meters and KW hr meters. The cost of each little part was going to add up beyond a factory built data unit.
Eco Diesel
« Reply #6 on: October 24, 2006, 07:38:11 PM »
Try -    www.yokogawa.com/us/mi/ for the good stuff! I especialy like the big look panel meters.
Troy
