Ok, I'll clarify again where we are:
General frame design looks pretty good ,depending on what we build it from , of course.
We're pretty much onto mounts now. Please, everyone, consider the following few things:
The converse of each statement is true as well, of course.
- More mass suspended gives less movement and a lower natural frequency.
- Stiffer mounts raise the natural frequency and increase the transmission of pulses to the outside world.
- More of the same mounts is equivalent to stiffer mounts.
There are two exciting frequencies at a speed of 650RPM, 10.8Hz from flywheel imbalance and 5.4 from firing pulses.
You do not want all your factors to come together to give you a resonant frequency near those two points. That would be bad.
How can you tell?
The undamped natural frequency in Hz = 1.88 x SQRT( spring rate in pounds/inch / mass suspended in pounds )
Undamped is close enough. Depending on how much your mounts dampen movement, the damped natural frequency could be a little bit different. But not by much.
You need the mass of your system and your spring rate. You can guess the mass pretty well. I'll say 1500 pounds for a basic engine + generator + frame. The spring rate? Squash your proposed mount and see how far it moves. If it takes 300 pounds to move it half an inch, that's a 600lb/in spring rate. Multiply that spring rate by the number of mounts to get the system rate for the use in that formula. (edit) Manufacturers will often give the deflection of the mount at a certain load - you can use that , as long as your load is close to that.
So using those two examples - 1500 pounds and 600lbs/in spring rate, with 4 mounts, I get a natural frequency of :
1.88 x sqrt ( 600 x 4 / 1500)
Which is about 2.37Hz. To get that back to RPM , times that by 60 to give about 142 RPM.
To get that to power pulses (which are half the speed of the engine) , times that by 120 to give 284RPM.
At these two points in the rev range, your engine will jiggle. How much? Who knows? It all depends on the damping in your mounts (which takes energy away from your jiggly mass) and how long you stay at that RPM (which puts energy into your jiggly mass)
But if your mass and spring rate combo give you a jiggle that works out around the 500-700RPM range, I'd be pretty careful about proceeding with that combo.
(Edit:) So, either :
Add more weight to bring the frequency down a bit.
Get softer mounts , or use less of them to reduce the spring rate.
To be honest, I'd probably not recommend trimming weight or going for stiffer mounts if your frequency works out around 650RPM. Strictly for reasons of safety - might be fine at 650RPM... but that one time you overspeed to 800 or 1000RPM, you'll hit the natural frequency and have to deal with a jumping as well as overspeeding engine.
