Gus needs bearings now although I remain concerned the crank is junk, I have a spare I just don't want to waste it in case Gus turns out too messed up to run reliably.
Somebody may need that crank around here someday...
On with the show.....
Any sugestions on how to get these bearings out?
http://www.putfile.com/pic.php?img=4482323I assumed they would come with some gentle beating with a blunt heavy object.
No but I did try and tap out the front main with a punch and a few taps from my big brass drift.
I email Powerline with pictures of everything asking for advice.
I suspect the Indians may press them out in the shop, in wich case I need to get yet another tool that will push the bearing out of the housing.
Another thing I have considered is peeling the bearing by nailing it with a smaller punch just one side to the seam between the two sides. a few good hits towards the center of the hole should colaps the bearing I suspect this might be the way it done in the field by some Indian mechanics.
In poses a new series if trials as well the new shell has a slight spring to it so I need to cook up some sort of piston ring compressor like jig to squeeze the bearing closed and round at the same time in order to press the new one in.
What the hell was I thinking?
Why did I blow my mad money onthis when I could have just bought an old Refer unit or something.....
Waiting on India now to tell me how they do this....
I'm going to upload more pictures of the bearing housing and the new bearings for all to see
