http://www.putfile.com/pic.php?img=3328679These are the heads on a Duetz 912 precup emmisions controled engine.
They make them in India
Bore 100mm stroke 120mm ( same stroke as the super Petter )
Four studs hold the head and cylinder on the block.
Are you reading this in Rajkot?
You guys make this head already and it passes not just tier one emmisions but Canadian M424.1 standard for use in non gassy mines ( a much tougher standard ). Can you build us this in a stationary twin with Lister fly wheels and water cooled block, can you add an oiling system like a bushed Petter with full flow and the original bypass?
These are all clone parts made in your own country build it and we will come.
