Recent Posts
Pages: 1 ... 8 9 [10]
91
Petteroids / Re: PETTER - PAZ1 - Back to 1st Petter
« Last post by sirpedrosa on July 16, 2019, 10:34:15 PM »
Hi Everyone
First project it's almost done!
After fine tuning the new gibkey, and tap it, it's ready to be fired up... Same modus operandi of the other one.
This one took me almost a year to rebuild.
Nothing like a pic with the before and now.
92
Everything else / Re: Diesel Heaters
« Last post by glort on July 16, 2019, 04:01:45 PM »
Bob,
Optus have a wireless Internet service that I have read many good things about. You can connect you home computer, laptop, tablet and phone all through the one connection and it's available everywhere you go..... more or less.  I think it's about $70 a month.  I have been meaning to look more into it myself.  The NBN that was supposed to be here 2 years ago has made it to the street. They were digging and making a mess down the end a fortnight ago and were supposed to be finished 2 Fridays back.  I am sure like the endless broken promises it will be another 2 months of fridays before it's all connected and then will be garbage when you do get it.
My windows there are the normal up down type although there are sliders elsewhere.
I was thinking to just get a Piece of suitable gauge Tin used for ductwork and the like and cut that to the window width and let the window sit down on it.
If I fold a lip in it, I can mount the heater to that and just have the hot air ducted in.  I was thinking to pull the air from the outside so as to give the house a touch of pressurisation so all the cold air in the gaps of the many doors is pushed out if anything.  I was also thinking to compensate the colder air intake by making a heat exchanger of a tube in tube design of solid pipes with teh exhaust running down the middle of the intake then exiting  well up and away from said intake.  I was thinking to put some twisted thin sheet metal down the centre of the exhaust tube to create some turbulence and break up the cold boundary layer gasses to give the best heat transfer.
I have tested the glow plugs I have and they glow quite a bright red at their rated Voltage of 11V and definitely ignite the oil I have dropped on them.
The question is how much oil can they ignite on a continual basis.  I haven't managed the current yet but I expect it to be about 5A.
I remember the Peugeot's were a real pains with teh glow plugs and had a propensity to go though them.  Not a matter of the glow time but I think the way they were located in the Cylinder.  Never changed the Plugs in my patrol in 4 years.  The ones in the Merc were average.  Lasted a good while before falling over.  The ones in the pug almost needed to be on a belt feed damn things.
I don't know about the WI, as I said, needed more thought.... and probably some testing.  I can see things for and against. First thing is IF a problem occurs for it to fix.  May not need it in the first place but then again, If I put on a system and the burner stayed clean, even if it would have anyway,  I could claim the WI was a success!    :laugh:
I'm not sure if the heater has any mixture adjustment. I have not seen mention of it.
In my burners it's more about keeping the heat in the burner and the fuel levels stable.  My bigh burners all run very air rich to make a clean burn.  With low output burners, it's real easy to over cool them. By reducing the airflow to what you need, one reduces the excess and the cooling allowing the burn chamber to remain hot enough to vaporise the oil.
I built a new burner a few weeks ago on a design I have had in mind for years specifically  for low output and complete combustion.  Must get round to firing it up and seeing how it goes. I already have another more compact and efficient design in my head that is based on another desighn I did years ago.  That one worked on the heat travelling back on itself  as well and was very effective. The outside of the burner was almost cool enough to touch while the inside was really hot and the output of the thing reflected how well the oil was phase changed to a gas and well mixed with the air.  It was an absoloute mongeral to light though  so I'm hoping this new idea over comes that.
I'll have to put some effort into the Draft burner as well. I always did like the way that one worked.  No external power or fuelling needed. Light and walk away for an hour then top up again and another hour of impressive heat with nothing to set flow rates on or anything else.
93
« Last post by EdDee on July 16, 2019, 03:24:39 PM »
I jump in to add my not even 1c worth....
<Quote:>
With respect to your idea of water injection, I doubt that this will do anything. In an ICE the water droplets work under high pressure on each compression stroke, this has a hydraulic/steam cleaning effect that you will not find in an low pressure burner system but I might be wrong and look forward to hearing what you discover.
<Unquote>
I have been playing around a little with this lately and found one interesting thing, haven't verified or documented it properly yet, but when I took the water from the over pressure bleed off/expansion valve of my boiler to the path of the flame, the stack cooled slightly overall, but I found the heat transfer to the heatex coil a little better... Could have been atmospherics, dumb luck, or error... As I say, I need to look into this a bit more, it could prove interesting....
Ed
94
Everything else / Re: ESD 5500E engine speed controller unit
« Last post by EdDee on July 16, 2019, 03:16:32 PM »
As usual, I'm jumping in half way with no clue whatsoever...
What about putting the prox adjacent to the blades on the genhead pickup.... Don't forget to set up some sort of safety for belt breakage etc that would rev the guts out of the system when it thinks its at low/0 rpm....
Otherwise, an internal mount in the sump to pick up rpm from the cam gear teeth.....(Or maybe a hole drilled in the case?)
Just spitballin'...
Ed
95
« Last post by ajaffa1 on July 16, 2019, 01:47:19 PM »
Hi Glort, it`s nice to have an internet connection again, ours failed about ten days ago. When we reported the problem to our telco, by landline telephone, they diagnosed that we needed to buy a new telephone despite the fact that I was talking to them on our existing phone! F*cking morons finally realized that it wasn`t just our property that had no internet, the whole district was disconnected. Eventually they sent out an engineer to reboot the ADSL router at the local exchange. Guess what, all the locals now have internet again, next time it goes out I`ll just go to the local exchange and kick the door in, turn the router off and restart it, problem solved! It`s not quite that simple, this problem occurs every six months, I suspect the router has a memory cache and error file that builds up until it is full at which point it falls on it`s face. A little routine maintenance and remote supervision would cure the problem but I`d bet my house it will fail again in December or  January. The real killer with these outages is that the local Canoe Center is unable to take bookings or deal with necessary bank transactions, I would estimate the financial loss at between $5,000 and $10,000, none of which the telco is responsible for unless we can prove negligence!
Enough of my problems, back to your project. I have never seen a glow plug that would heat diesel/kero/veg to the point of ignition. Much more likely it heats it to increase volatility before passing it through an atomizer nozzle with a spark igniter. Once alight the fuel burn should be self sustaining. I think I suggested before that a gas pilot light could easily replace the spark igniter and would be better suited to igniting veg oil.
Your concerns about the dangers of mixing diesel/RUG are unfounded. I recently wanted to quench some red hot steel parts in oil, the only oil I had available was a 5% RUG/diesel mix left over from fighting the forest fires earlier this year. I filled a container with the mixture, dropped the red hot steel into it and ran like f*ck. I was expecting it to ignite or worse but nothing happened, it did boil rather harder than neat diesel but left a very nice blued finish on the steel. I continued with this process for over an hour with no ill effects until I managed to boil the Diesel/RUG mix at which point it spilled out of it`s container and all over the shed floor! So much for health and safety.
I like your idea of feeding the hot/return air through a window, I have no idea about which way your windows open but a sliding window could easily be modified with a small strip of plywood to allow for the inlet and outlet pipes, without effecting the window.
Generally you need to adjust the fuel air mixture in any burner until you have no signs of yellow flames; blue is good, yellow/orange produces soot and blocked chimneys and all the associated dangers, carbon monoxide and etc.
Let us all know what you find out.
« Last post by old seagull man on July 16, 2019, 12:51:37 PM »
Yes and no. The unit uses a proximity sensor to count the teeth on the prime power flywheel. To monitor the engine speed.
The mighty Shifing is hand started so the flywheel has nothing to count. An one of the boys decided they needed it for a job they were doing so, I'm out of luck.
97
« Last post by old seagull man on July 16, 2019, 12:47:30 PM »
Put me down as interested as well. My container workshop is bloody freezing these mornings. and i do have a bit of fish and chip oil around the place.
98
Original Lister Cs Engines / Re: Start-o-Matic baseplate - thread type?
« Last post by glort on July 16, 2019, 12:08:10 PM »
Thank your preferred Daiety for metric.
So much simpler and practical that the 173 flavours of Imperial.
99
« Last post by glort on July 16, 2019, 12:05:26 PM »
Hi Bob,
Looking into these things some more, I am sure they will NOT run on anything but a substantial Diesel/ Bio Blend.
They work by feeding the fuel over a glow plug which vaporises it so it can burn. As far as I can tell, the GP must be on all the time because I can't see any other way for it to self sustain sufficient heat.
Any waste oil will carbonise on the plug and cause the heater to stop working. They are a ceramic type plug which is said to be brittle and expensive ( $30+ in a $150 heater.
A low conversion Biodiesel should work OK but I have my reservations about blends although the guy I communicated with reckons he was doing OK with 50%  Diesel / Veg oil. I suspect he is using new oil  That's not economical but he seemed environmentally conscious so that may be his motivation if that is what he is using. If Bio could be made for what I think presently, around .50C a litre or less, it would be well worth the Minimal effort required.
A processor could be set up that required nothing more than mix the meth-oxide, throw it in the reactor and let it mix  a while.
When I used to do the 1000L batches with a mate we used to mix for an hour ( with a geared down Motor driving a 25HP outboard propeller in the tank)
Then let it rest an hour, Drain the Glyc, Remix a while then let sit and drain the final Glyc.
I'd set it up with a DC fan motor running off a panel and let it mix a day or 2 settle a day or week then pump off the top of the drum.  For a burner I wouldn't even take the Meth out, it would help with ignition and any soap which the meth usually holds wouldn't matter anyway.
If one were using engine oil it could be Cracked to remove a lot of the ash producing impurities which would make it much cleaner burning that way.
I have been doing a bit behind the scenes with control system for burners.  Using pumps and PWM controllers for the fans allows much more stable output at low outputs.  I have also done a bit of tinkering with some glow plugs left over from my Lovely but completely unreliable Peugeot and dribbling oil onto those.  I believe they have the grunt to burn off any deposits from used oil and am doing the mental arithmetic how to best utilise them in a DIY burner.
I am thinking of them as a pre ignition/ heater for the oil which may be employed as either a way to get faster and possibly even push button starts of a burner or just good stability at lower outputs. Using waste oil is a bit of a trick over Diesel / kero/ turps/Bio etc because it burns with a lot of residual crap unlike the refined fuels that burn clean.
I believe the heaters are safe, they have over temp sensors and it they had caught fire, pretty sure it would be all over the net by now.  Everything I can find rather than complaining typically about " Chinese Rubbish" seems to suggest these are better than the webastos and Esbarchers they copy.
I have read a good number of comments from people that have had those which cost many hundreds of pounds/ Dollars and tried the Chinese heaters and said they are vastly more reliable and trouble free.
This place has I think more windows than walls so I was thinking to  make an insert for the heater to sit in one of the windows in the middle of the house.
The whole thing could be outside and set back a bit from the window so if it did go up, it would be pretty free and clear of anything combustible.
I have a few 40oC temp switches left over from attaching to Solar GTI's to kick in external cooling fans so one of these mounted on the unit to a Buzzer ( car horn) would add a degree of comfort to my paranoia.
I was thinking of RUG in the mix and as cautious as I am with that, I can't see a problem with it here.  There is really no opportunity for a deflagration of any consequence as long as the ratio is kept low. I don't use it above 10% in engines and if its going to vaporise at any time and cause a build up of flammable gasses in the unit, it might be better to light them off earlier with the RUG than allow them to build more as they will anyway with diesel. The combustion chamber has an always open path in and out so no opportunity for pressure build up anyway. Might get an amusing pop  but that would be about it.
The other thing I was thinking about was my beloved water injection. If there were a way to get a very slow drip into the intake of the burner it may help with keeping the combustion chamber clean  and deposits at bay. There is a bit that needs to be thought through with it however.
You don't need one of these for shed heater, I already have designs for those that will heat a warehouse! these diesel heaters do 5 KW output. If you were careful you could  keep one of my heaters down to  50 Kw..... Maybe....
The things I have been playing round with would definitely allow control and workable output for a shed heater and you could burn any waste oil you could get hold of with no worries.
Gravity feed is OK for shipfluckery in the back yard but for any serious heating where you don't want to have to stand over the burner or never be more than 6 Ft away, Pumping is the way to go.
That said, I'm also working one an old batch burner design I never actualy made a vid of but used it a lot at home myself.  Mrs and I would often go and sit  round the thing in the yard in the middle of winter listening to it quietly roar away and the only time we got cold was when we came inside.
This is a batch burner setup so depending on the size of the thing and how hard you run it, You only have to top it up every so often. Mine used to throw out a lot of heat ( about 50 Kw) and I only had to top it up every hour.
Spsoe I should get into the vids like I have been saying I will... forever, before winter is over again.
100
« Last post by 38ac on July 16, 2019, 11:31:27 AM »
 They are very likely 1/2 UNC. Most of the Lister equipment of that vintage that I have been around was marked if manufactured with  Unified threads. I don't believe that the CS engine was ever changed but that is only based upon what I have had my fingers in. The UNC and UNF thread patterns follow the SAE(coarse) and USS(fine)  patterns of the United States with tolerances being the only difference. They are interchangeable other than critical applications.  The 1/2 UNC at 13 TPI does differ from BSW at 12.
Thread gauges are cheap. Id bet that a 1/2 USS capscrew will thread right in.
