Lister Engines => Original Lister Cs Engines => Topic started by: Samo on October 15, 2018, 03:30:35 PM
Title: CAV Pump Leak
Post by: Samo on October 15, 2018, 03:30:35 PM
Hey folks,
Been a while since my last post, finally getting some time again to work on the last few things for my Lister 12/2. So even though it runs I've noticed that one of the Diesel pumps is leaking (squirting) fuel out of the port near the bottom of the pump. it's not coming out of the bottom, just that oval port on the side of the pump.
Does this mean it needs a rebuild? Anyone know of a rebuild kit for these?
Any advice appreciated
thanks,
Samo
Title: Re: CAV Pump Leak
Post by: ajaffa1 on October 15, 2018, 09:48:50 PM
Hi Samo, welcome back. Sound like the element in your pump is scored or corroded and will need replacing. Should be a 7 mm element available here https://www.stationaryengineparts.com/Lister-CS-CAV-and-Bryce-Type-7mm-Fuel-Pump-Element.html
Post by: Samo on October 17, 2018, 12:56:39 PM
Thanks Bob, that looks worth taking giving a go.cheers
Samo
