How to / DIY => Engines => Topic started by: RiK1200RS on February 01, 2018, 01:16:49 PM
Dear all,
Let me briefly introduce myself. I am Rik, 35 years old from the Netherlands.
Currently I am rebuilding a barnfind ST1 into a backup generator. The ST1 has completely been overhauled, due to serious neglect by the previous owner(s).
On the front side of the engine (next to the oil filter) I found a mount, for what appears to be a fuel lift pump. Since a lot of parts on this engine were either broken or missing, I bought a lift pump for my purpose.
When browsing for the fuel lift pump I found a pump, for this particular ST1 (which has some kind of "lobe" on it), but it doesn't seem to match the engine. The lift pump which (in my opinion) should be mounted should have some sort of rod, which connects to the pump. So it should be driven by one of the cam lobes inside the engine (similar lobe as the oil pump I think).
Is anybody able to shed a light on this matter? Do I have the wrong pump (HFP115) or am I missing some parts on the ST1 side?
Your help is highly appreciated.
Many thanks!
Your engine will need the fuel pump pushrod and guide installed for the external lift pump to work.
Thanks Dieselgman for the heads-up.
Do you by any chance have the partnumbers for the missing parts?
I will try to track them down. Or maybe find my luck here on the forum.
Thanks!
We should have some stragglers in stock... $20 guide, $15 pushrod.
Great! Do you also ship to NL? Saves me a lot of searching (needle haystack kind of thing) and we have some little business.
What will be the big total with shipping?
Thanks, again!
You may email me for invoicing and shipping details.
gary@dieselgen.com
