Lister Engines => Original Lister Cs Engines => Topic started by: Mr Lister on January 22, 2006, 05:12:32 PM
Guys,
This week I have been rebuilding an engine I bought last February which had a leaky exhaust valve and some fuel injection problems.
Here is a brief account of how I got it running again.
This weekend I have rebuilt the valve gear on a 1951 Lister CS 6/1 by
fitting new valve guides, valve springs and lapping in the two new valves
with grinding paste.
I was a little concerned about the exhaust valve still leaking a bit of
compression, but this has now settled down and a reasonable amount of
compression has been restored.
I had the same problem with my injector pump as Andy was experiencing. It
was pumping fuel to the injector, but without sufficient pressure to fire
the injector.
After consulting fellow enthusiasts on the stationary engine list, I was
advised to undo the fuel delivery pipe on the top of the injector pump and
check that the delivery valve was working correctly.
On unscrewing the top "nut" from the injector pump and watching out so as
not to lose the spring, I saw the top of the delivery valve which looks a
bit like a bowler hat. It is located in the centre of a cylindrical
chamber into which the nut screws. This chamber is normally full of high
pressure fuel and the delivery valve opens with the rising fuelpressure as
th pump plunger rises, and then snaps shut unter the action of the spring.
The delivery valve has to be free to move up and down by about 1/8" inorder
to work correctly. Mine was stuck in the up position, allowing fuel to
leave the pump when the plunger was pushed in, but also flow back when the
plunger retracted.
The solution to my problem was to free the delivery valve by tapping it
downwards VERY GENTLY with a mandrel made from a short length of small bore
tube. (Microbore copper would probaby do). The valve had seized in the open
postition and neededa couple of gentle taps to get it to loosen off. This
could be assisted by soaking the valve and the delivery chamber overnight in
WD40.
Once free, the valve pops up with the plunger pressure and sinks downwards
as the plunger retracts.
To test the injector, I removed it from the cylinder head and laid it on top
of the head and facing away from me.
(VERY IMPORTANT - this injector will shoot toxic diesel fuel about 4 feet
distance at 110 atmospheres of pressure - it would instantly blind you if
you got it in the eye, and will even inject fuel into your skin if you get
in the way. It will continue to shoot fuel at this pressure even if the
flywheel is turning very clowly or just over the injection point - TAKE
CARE!)
I reconnected the high pressure fuel deliver pipe and turned the engine
over several times. After about 40 revolutions, the injector fired a good
spray of fuel, and closed with a satisfying creak sound.
Now that I had fixed my fuel problem, I was keen to crank the engine over an
get it to run.
It had no air cleaner, no exhaust pipe or muffler, and the diesel was
temporarily rigged up in a 1 litre bottle sitting on topof the fuel filter
and wired to the cylinder head.
After a few starting attemptsit gave a couple of grey smokey puffs from the
exhaust port.
We then got a small propane torch and held the flame about 6" from the inlet
port. This was enough to preheat the combustion air, but not so close that
the engine only sucked in burnt propane fumes (CO2 and H20). After about 3
minutes of gentle warming and turning the engine over - decompressed, with
the starting handle we got it to start. The first real power stroke blew
out a lot of soot into my helper's face, and I man-handled the fuel pump
rack to maintain a reasonable constant rpm, because this engine was lacking
the governor spring.
I noted that it was quite responsive to the position of the rack, and
pulling out the rack a little was accompanied by a few very loud power
strokes and sparks of burning carbon shooting out of the open exhaust port!
After about 5 minutes of playing the throttle, I shut the engine off,
because I had been running it without coolant, and the old oil in the sump
was less than adequate for continued running.
Chuffed to bits!
Ken
Thanks Ken for the very informative posting. I was getting rather annoyed at all the strutting and puffing on this forum. It's nice to see someone posting information germain to the subject and stating the steps clearly and concisely to troubleshoot a lister (or oid, as the case may be). For those of us who are intending to be owners in the near future, this kind of post is a godsend.
Stan
ps...it's also nice to be able to attach a name to the poster, rather than some enigmatic non de plume.
Stan,
Thanks for your post.
I agree that what this list needs is plenty more sound practical advice on how to work with these engines regardless of their age and manufacturer.
Yesterday I gave up on the injection pump because I had heard a rumour that if you start to mess with them they end up a can of worms.
I sought advice from someone who regularly maintains them, he said that I could proceed with confidence into the elivery valve chamber without risk of damage to the plunger and any of the more precision areas of the pump. This is the sort of knowledge that needs to be shared amongst the group.
I grew up in the 70's and messed around with model glow engines, but had never worked on full size diesels before.
There is nothing hard or complicated about the Lister, you just need a few correct tools and the confidence to proceed with the repair.
I think that anyone who wants to run a Listeroid should have a go at a strip-down and rebuild to see how straight forward it is.
I now have another working engine, from one that was bought last year in a non-running condition and I have had a satisfying, but oily weekend!
Ken
Ken, A very good to know post on stuck injector delivery valve, and a most enjoyable read about your resurrection of a 55 (!) year old Lister. Thanks! Bruce
BruceM & list,
The 1951 Lister is now back on it's trailer.
There are a few of photos of it on my Lister News site:
www.powercubes.com/lister_news.html
The new valve gear works fine and it started first swing. Not bad for something that has not run for 20 years or so.
Ken
BruceM & list,
Ken
Ken, thanks for the link. This is a good looking setup. Two questions:
Does it jump around on that trailer?
Can you please tell me more about the propane cylinder coolant tank? That looks simple and practical.
Thanks
Russell
Russell & list,
The engine is pretty stable on the trailer when running a 2kW or greater load. The biggest problem is the water tank which dances a merry jig at a certain engine rpm.
The propane tank was a salvaged unit with a busted valve. It holds about 6 US gallons of water.
I left it lying out in the sun with the valve open for about 3 months and then removed the last of the busted valve with a big wrench. I guessed by that time most of the propane had "left the building".
I then flooded it with water a couple of times before I took it down to the village blacksmiths shop (yes -for real), where he welded in the upper and lower 1" pipes and the bit of 2" diameter scafolding pole to make a stanchion post.
The engine will run all day at a show with just 5 or 6 gallons of cooling water but you will see it boil in the outlet pipe from the head!
But as Listers say in the original manual "this is a heat engine - it likes to run hot"
Ken
Ken,
One thing about the English Lister (why does everybody say British these days?) and the Indian versions that I've often thought is a potential problem for many of us going forward is parts availability for the injector pump. From your experience with the older engines, do the injector pumps ever get worn and start to have problems getting up pressure? If so, are parts still available?
Quinn
Quinn,
To the best of my knowledge spare parts are still available -at a price.
I found one with a stuck delivery valve, and several with stiff or siezed racks.
One engine I collected 2 weeks ago had had the original IP, replaced by a Mico pump.
With regards to worn out pumps, I am yet to find an engine with a totally useless pump.
Ken
Great to hear an old machine is running again.
I guess I missed all the warnings about taking apart pumps and injectors...I had mine apart the first couple of days and glad I did. Both were stained and dirty from the nasty Indian fuel.
Old gunsmith trick for removing stains from highly polished and critically fitted parts--- Use the charred end of a wooden dowel. The charcoal is abrasive to the stain but not the steel and it can't change tolorences.
Hi Jack,
Good to hear you again. Do you sometimes get the feeling these English guys enjoy teasing us with their stories of these great old engines found evidently without great effort, and to be had for not much dough? ;)
Quinn
dunno, but I may have found two more going for 200 pounds
For years I heard of the old farmers with Boss, Purdy, and Holland shotguns in the closet not being used and could be had cheap in the English countryside. In 1985 when the pound was $1.03 I gathered up all the cash I could and flew by Peoples Express to Gatwick and spent two weeks beating the English and Scottish bushes for good shotguns, cheap....and found a bunch of them. ;D
I wish Listers were as easy to ship and clear customs. :(
George from Utterpower recently sent around a test version of "How to fiddle around with your injection pump", I'm paraphrasing. Nice pics and typically straightforward diagnostic recommendations.
I think I have a copy stashed away if any would like to see it by email.
The main thrust of the article was, work in a very clean environment, pay attention, and read up a bit before you do something silly. You'll do fine.
I completely concur that you need to pay attention around high pressure liquids. If there's a leak in the injection system of an industrial installation, a typical aid to find the source of the leak is a piece of paper taped to a long stick. If your hand gets in the way of the high pressure stream, it is possible to get your finger just about cut off. Never mind the toxic diesel that gets shot into your flesh.
Finest regards,
troy
they are, ship as parts, it's really not a big deal....
got two 6/1s, see for sale forum
It's a big deal when I can ship $100,000 in guns for what one Lister would cost!! When buying cast iron it's good to either be buying close to home or by the ship load.
True scrap iron is shipped in open holds and loaded/unloaded by magnetic crane......now if we could buy a lot of a hundred tons of scrap engines and sort through them later.... ;D
Off topic but a topic of pride-- I once built a rifle from parts bought from a gondola (train) car of scrap military weapons destroyed by cutting torch and shear (for $.50/pound) that later sold for more than $150,000. The gun was built 32 years after I bought five dollars worth of "scrap iron".
Pics and ref. on request. NO commercial interest...ect.
Guys,
I have acquired another 1951 6hp engine needing a rebuild - this time a Startomatic engine. I will use Indian parts on this one - now that our shipment form India is landed in the UK.
The pictures are on the LCSOG (Lister CS Owners Group) (coppermine would not play ball)
http://groups.yahoo.com/group/Lister_CSOG/
Following this morning's 2 hour voyage into the unknown, I can now report
some progress in stripping down the 1951 6hp SOM engine.
Basic tasks accomplished today:
Rocker cover off
Valve rockers off and useable
Cylinder head off
Valves and guides and springs out and reusable with a little regrinding
Cylinder - twice subject to frost damage, repaired once - basically toast.
Bore was surprisingly clean and pit free *
Piston -, calcium deposits, rings all stuck, should clean up well, going
to dunk it in a jar of diesel for the next week
Little end -OK
Big end, minor wear but serviceable
Mains - OK,
Injector pump - iron oxide based lifeform!
Injector - replace
Cam shaft, gears and tappets free and serviceable
Push rods -a little weathered ;-)
* Piston and bore had accumulated a kind of hard calcium carbonate (chalky,
limescale) oily deposit that bungs things up and is fairly tough. Will come
off with gentle scraping. I guess this could be a minor leak of coolant
water, that then boils in the hot bore and on top of the hot piston and
leaves about 0.5mm of limescale behind on the top of the piston and seeps
down towards the top ring.
I now need to drain the sump and steam clean and take the grinder and
wirebrush to the crankcase and flywheels.
Bearing in mind that I have only had 4 hours on this engine and it's nearly
in bits, I would say that a less rusty could be totally stripped down,
assessed and rebuilt in a day or two.
I drove out the valve guides with a round drift and they came out with
almost no fight. The lower end of the exhaust guide gets very hot in usage,
and the cast iron tends to embrittle. Mine has lost about 4mm in length from
a new part.
A drift made from brass or aluminium turned to the valve stem diameter would
the best tool to get these out. The exhaust valve guide threads in for
about half inch, then you have to drift it.
The injector pump and injector are unlikely to be salvageable, the oilpump
seems free but the cam that drives it is stuck firm in the fully out
position.
Tomorrow I will remove the cylinder studs (double locknut method) and get
the crankcase ready for steam cleaning.
There is one fascination with these big old engines, the great thing is that
the parts are big and chunky and very forgiving.
regards
Ken
Guys,
The latest Lister pictures from this side of the pond are at
http://www.powercubes.com/lister_news2.html
This issue of Lister News Includes:
Andy Mahoney's Homebrew Power System
Stripping down a 6hp 1951 Startomatic - The Good, The Bad and The Ugly!
Collecting a 1948 Startomatic from Cambridge
I am always on the look out for content, please email pictures or short articles, queries etc to ken.boak@gmail.com
Ken
Probably not relevant to a small vertical engine like this but I will throw out this caution anyway.:)
I have listened to more then one story of large engines on trailers running at shows while still connected to the tow vehicle. At the end of the show the owner goes to drive the thing home only to find the U joints and or gear box have been pounded into junk. I am guessing that if they had set the parking brake instead of just leaving it in gear there would not have been a problem. These were large horizontal engines, 5000 to 10000 pounds for just the engine.
___________
Andre' B.
