Lister Engines => Lister Based Generators => Topic started by: johnny williams on January 19, 2006, 09:39:49 PM
Does anyone know of an inexpensive device that will convert 400Hz to 60 Hz?
analog tech motor-generator.
digital tech frequency converter.
both have been used on US submarines. The frequency converter is current issue.
What are you trying to power?
House,shop whatever
non reactive loads will run on 400Hz no prob, not sure about powering switching power supplies.
I know an old trick to run 400Hz radio gear on 60Hz was to wire a second transformer in with the respective input and output windings wired in series. It usuable ran warm but didn't burn out.
You may want to try running a cheap transformer wall brick on 400Hz to see what happens.
